P2P RN2903/RN2483 Arduino
So I have gotten a little farther in my LoRa knowledge. I think I managed to get a Gateway set up. But now I am having trouble with P2P comm between two modules. I set up two RN2903 modules with Arduino’s using this setup:
My “Send” Code is:
#include <SoftwareSerial.h>
SoftwareSerial loraSerial(10, 11);
String str;
void setup() {
  //output LED pin
  pinMode(13, OUTPUT);
  led_off();
  // Open serial communications and wait for port to open:
  Serial.begin(9600);
  loraSerial.begin(9600);
  loraSerial.setTimeout(1000);
  lora_autobaud();
  led_on();
  delay(1000);
  led_off();
  Serial.println("Initing LoRa");
  loraSerial.listen();
  str = loraSerial.readStringUntil('\n');
  Serial.println(str);
  loraSerial.println("sys get ver");
  loraSerial.println("mac pause");     // Activates P2P transmission between the modules
//  loraSerial.println("radio set bt 0.5");
//  wait_for_ok();
  loraSerial.println("radio set mod lora");
  loraSerial.println("radio set freq 915000000");
  loraSerial.println("radio set pwr 14");
  loraSerial.println("radio set sf sf7");
  loraSerial.println("radio set afcbw 41.7");
  loraSerial.println("radio set rxbw 125");
//  loraSerial.println("radio set bitrate 50000");
//  wait_for_ok();
//  loraSerial.println("radio set fdev 25000");
//  wait_for_ok();
  loraSerial.println("radio set prlen 8");
  loraSerial.println("radio set crc on");
  loraSerial.println("radio set iqi off");
  loraSerial.println("radio set cr 4/5");
  loraSerial.println("radio set wdt 60000"); //disable for continuous reception
  loraSerial.println("radio set sync 12");
  loraSerial.println("radio set bw 125");
  Serial.println("starting loop");
void loop() {
  led_on();
  loraSerial.println("radio tx 6C6F"); 		//This line does the actual transmission. 6C6F is the data packet in HEX
  led_off();
  delay(2000);
void lora_autobaud()
  String response = "";
  while (response=="")
    delay(1000);
    loraSerial.write((byte)0x00);
    loraSerial.write(0x55);
    loraSerial.println();
    response = loraSerial.readStringUntil('\n');
 * This function blocks until the word "ok\n" is received on the UART,
 * or until a timeout of 3*5 seconds.
int wait_for_ok()
  if ( str.indexOf("ok") == 0 ) {
    return 1;
  else return 0;
void led_on()
  digitalWrite(13, 1);
void led_off()
  digitalWrite(13, 0);
and my Receive code is:
String str;
char e  ;
void setup() {
  //output LED pin
  //led_off();
  Serial.begin(9600);
  lora_autobaud();
  led_on();
  delay(1000);
  led_off();
 wait_for_ok();
wait_for_ok();
 wait_for_ok();
  loraSerial.println("radio set wdt 0"); //disable for continuous reception
void loop() {
  //Serial.println("waiting for a message");
  loraSerial.println("radio rx 0"); //continous reception
   char e = loraSerial.read();
         //  if (loraSerial.available() > 0) {
    str = String("");
    while(str=="")
    if ( str.indexOf("radio_rx") == 0 ) {
          Serial.print("packet: ");
    Serial.println(e,HEX);
      toggle_led();
    else
      Serial.println("Received nothing");
  else
    Serial.println("radio not going into receive mode");
    delay(1000);
    delay(1000);
int wait_for_ok()
    return 1;
  else return 0;
void toggle_led()
  digitalWrite(13, !digitalRead(13));
void led_on()
void led_off()
All I get is:
packet: FFFFFFFF
Any ideas?
start by reading… How do I format my forum post?
we don’t like big chunks of copy/pasted code… you can also link to github for example.
Also don’t try to write a ‘tutorial’ if you have yourself little knowledge of the subject, there is a lot of good information on this forum, just use search.
P2P communication between 2 nodes using LoRa has nothing to do with LoRaWAN.
topic closed
