# 8, 16 and 64 channel gateway in US
**URL:** <https://www.thethingsnetwork.org/forum/t/8-16-and-64-channel-gateway-in-us/32576>\
**Category:** Gateways\
**Created:** [December 11, 2019, 3:03pm UTC](https://www.thethingsnetwork.org/forum/t/8-16-and-64-channel-gateway-in-us/32576 "2019-12-11T15:03:40Z")\
**Showing post:** 7
**Author:** ![Clams](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/clams/32/35697_2.png) [@Clams](https://www.thethingsnetwork.org/forum/u/Clams)\
**Post date:** [December 12, 2019, 6:11pm UTC](https://www.thethingsnetwork.org/forum/t/8-16-and-64-channel-gateway-in-us/32576/7 "2019-12-12T18:11:28Z")
One thing: do not mix number of channel and receiver: the current gateway chip (based SX1301) have 8 channels and 8 receivers so you can only ever only receive 8 packet at the same time, but the next chip (SX1302) has 16 modems for 8 channels, so with this kind of gateway you can actually receive up to 16 frame at the same time supposing they are using a unique combination of channel and SF.
And about the use of 2 gateway monitoring the same frequencies: you could see clear benefits if you limit the spreading listen by each gateway: for example one for SF 5 to 8 and another for SF 9 to 12.
_[View the full topic](https://www.thethingsnetwork.org/forum/t/8-16-and-64-channel-gateway-in-us/32576)._
