# 865-868MHz Patch Antenna on PCB
**URL:** <https://www.thethingsnetwork.org/forum/t/865-868mhz-patch-antenna-on-pcb/3272>\
**Created:** [August 27, 2016, 9:16pm UTC](https://www.thethingsnetwork.org/forum/t/865-868mhz-patch-antenna-on-pcb/3272 "2016-08-27T21:16:32Z")\
**Showing post:** 26
**Author:** ![aizukanne](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/aizukanne/32/35697_2.png) [@aizukanne](https://www.thethingsnetwork.org/forum/u/aizukanne)\
**Post date:** [January 5, 2019, 12:00pm UTC](https://www.thethingsnetwork.org/forum/t/865-868mhz-patch-antenna-on-pcb/3272/26 "2019-01-05T12:00:09Z")
> [@BoRRoZ](#):
> [https://www.ti.com/lit/an/swra227e/swra227e.pdf](https://www.ti.com/lit/an/swra227e/swra227e.pdf)
I implemented this design in single mode. From all tests, with obstacles in the path, performance is very similar to a 1/4 wave dipole. However with a clear path i see a the PCB antenna RSSI better than that of a dipole antenna by at least 10units.
Here is a picture of both devices used in testing.
![PCB%20Antenna%20Test](https://www.thethingsnetwork.org/forum/uploads/default/original/3X/2/4/24ba41c4e87e5490a56be5bb082f8a7846458cd2.jpeg)
_[View the full topic](https://www.thethingsnetwork.org/forum/t/865-868mhz-patch-antenna-on-pcb/3272)._
