Hello Everyone,
I am using S76G node and trying to connect with TTN server but i failed.
What should I do for this till now my Status for device is never seen.
Hello Everyone,
what did you try ? and how did you code it .
and provide a link to that product pls .
@BoRRoZ Thanks for your response. I am using docklight/termite software to communicate with node to TTN server using command reference guide of S76G. Using the command reference guide pdf m running few of the commands on Docklight/Termite both of the software’s but m not getting any data on the TTN server plus there is never seen status in my application.
Here, I am sharing the link.
so you are using the eval board ?
Please be far more specific if you expect people in the forum to be able help you. Like: which commands, what do they return? And what’s your setup in TTN Console? Do you even have a gateway in your neighborhood? We also need a link to the documentation. (Like the specifications just mention LoRa, not LoRaWAN.)
Hi arjanvanb,
Thankyou for your response, We have setup 2 gateways in our office only. In TTN Console, in application we have registered the device. Please let me know which document are you talking about?
If you want to know about the product, that we have already mentioned above. I will also attach the commands. I wanted t know that have you worked on s76s or s76g?
If you don’t answer the questions asked normally, I assume you don’t want/need help and I will close this thread,
We have solved this problem. Thank You everyone for your supporting.
and thank you for wasting someones time.
