# Adding Application with specific AppEUI
**URL:** <https://www.thethingsnetwork.org/forum/t/adding-application-with-specific-appeui/18035>\
**Category:** v2 Backend\
**Created:** [September 20, 2018, 4:17am UTC](https://www.thethingsnetwork.org/forum/t/adding-application-with-specific-appeui/18035 "2018-09-20T04:17:13Z")\
**Showing post:** 8
**Author:** ![dmocci](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/dmocci/32/20484_2.png) [@dmocci](https://www.thethingsnetwork.org/forum/u/dmocci)\
**Post date:** [February 14, 2019, 3:26pm UTC](https://www.thethingsnetwork.org/forum/t/adding-application-with-specific-appeui/18035/8 "2019-02-14T15:26:48Z")
Hi @VS1, I made the following:
1. Run the Conduit Gateway in NS mode and change the frequency band to US915 (Netvox devices are set up with AU915).
2. Set up the APP KEY & APP EUI in the GW.
3. Set up a mdot US915 with this credentials and made successful join !
Then,
1. Go back to AU915 in the Conduit.
2. Try with Netvox device, but no join, and no failed join request.
By the way, The default uplink channel frequencies of these AU915 devices are 916.8MHz, 917.0MHz, 917.2MHz, 917.4MHz, 917.6MHz, 917.8MHz, 918.0MHz, 918.2MHz 917.5MHz(@BW500)
Is there anything missing ? How I can check that the frequency change is well set up?
Thanks!
Diego.
_[View the full topic](https://www.thethingsnetwork.org/forum/t/adding-application-with-specific-appeui/18035)._
