Adding sensors to a lora node
(Nidaros) #1
Hi all,
I'm new to the LoRaWAN network, I've succesfully setup my gateway and a node.
For the gateway im using a rasperry pi with a Dragino Lora/GPS hat. And for my node I use an Arduino UNO with a Dragino Shield.
I recently bought a 36 in 1 sensor kit for the Arduino. I've setup most of the simple sensors, including the analog temperature sensor, it seems to work just fine.
I've done some google searches and I can't seem to find any detailed instructions on how to send sensor data to LoRa WAN.
Can anyone help me with this?
This is my temp sensor script:
#include <math.h>
int sensorPin = A5; // select the input pin for the potentiometer
double Thermistor(int RawADC) {
  double Temp;
  Temp = log(10000.0*((1024.0/RawADC-1)));
  Temp = 1 / (0.001129148 + (0.000234125 + (0.0000000876741 * Temp * Temp ))* Temp );
  Temp = Temp - 273.15;            // Convert Kelvin to Celcius
   //Temp = (Temp * 9.0)/ 5.0 + 32.0; // Convert Celcius to Fahrenheit
   return Temp;
void setup() {
 Serial.begin(9600);
void loop() {
 int readVal=analogRead(sensorPin);
 double temp =  Thermistor(readVal);
 Serial.println(temp);  // display tempature
 //Serial.println(readVal);  // display tempature
 delay(500);
I hope to find some information from the real experts here :slight_smile:
  • Stijn
(Nidaros) #2
Bump
How to send payload from a sensor over LoRa?
(Rustie0125) #3
You need to use a Lorawan library, im not sure if the Dragino Shield bboard comes with its own library but i used this guide and setup, all you need todo is change your pins to match the UNO.
https://www.thethingsnetwork.org/forum/t/got-adafruit-feather-32u4-lora-radio-to-work-and-here-is-how/6863
(Nidaros) #4
Hey, Thanks for the reply. I got my lora node working, I was just wondering how to add a sensor (temp, gps eg.) and send the payload to TTN. As of now I can only send simple strings.
#5
Something like this:
I assume your data is an integer (int) value and therefore 2 bytes:
// map it to dataTX; 2 data bytes
   * Suggested payload function for this data
   *   var temperature = (bytes[0] << 8) | bytes[1];
   *   return { payload: temperature / 100.0 };
dataTX[0] = temp100 >> 8;
dataTX[1] = temp100 & 0xFF;
And the send would then be something like: LMIC_setTxData2(1, dataTX, sizeof(dataTX), 0);
You don't need sizeof -1 as you are not sending a string.
If you have more data, you can use [2],[3] etc.
Note; consider temperature being negative! I normally add 273.1 to Celcius to get degrees Kelvin. You can subtract this in the payload function.
(Nidaros) #6
This is what we have right now:
// MIT License
// https://github.com/gonzalocasas/arduino-uno-dragino-lorawan/blob/master/LICENSE
// Based on examples from https://github.com/matthijskooijman/arduino-lmic
// Copyright (c) 2015 Thomas Telkamp and Matthijs Kooijman
// Adaptions: Andreas Spiess
#include <lmic.h>
#include <hal/hal.h>
//#include <credentials.h>
#include <math.h>
#include <stdlib.h>
#ifdef CREDENTIALS
static const u1_t NWKSKEY[16] = NWKSKEY1;
static const u1_t APPSKEY[16] = APPSKEY1;
static const u4_t DEVADDR = DEVADDR1;
#else
static const u1_t NWKSKEY[16] = { 0x84, 0xF4, 0x45, 0x69, 0x52, 0x66, 0x5F, 0x2E, 0x3F, 0xC4, 0xFC, 0x50, 0x29, 0x64, 0x10, 0x35 };
static const u1_t APPSKEY[16] = { 0xDE, 0xBD, 0xAF, 0xC8, 0xDD, 0xC4, 0x3B, 0xF3, 0x82, 0xEA, 0x9C, 0xC9, 0x8D, 0x25, 0xA4, 0xFF };
static const u4_t DEVADDR = 0x260110BF;
#endif
// DISABLE_JOIN is set in config.h, otherwise the linker will complain).
static osjob_t sendjob;
// cycle limitations).
const unsigned TX_INTERVAL = 20;
// Pin mapping Dragino Shield
    .nss = 10,
    .rxtx = LMIC_UNUSED_PIN,
    .rst = 9,
    .dio = {2, 6, 7},
void onEvent (ev_t ev) {
    if (ev == EV_TXCOMPLETE) {
        // Schedule next transmission
double read_thermistor(int RawADC) {
  double Temp;
   return Temp;
void convert_to_string(char * outStr, int length, double val){
    snprintf(outStr,length,"%f",val);
void do_send(osjob_t* j, double temp){
    // Payload to send (uplink)
    uint8_t message[10];
    convert_to_string(message,2,temp);
    } else {
        LMIC_setTxData2(1, message, sizeof(message)-1, 0);
        Serial.println(F("Sending uplink packet..."));
void setup() {
    Serial.begin(115200);
    Serial.println(F("Starting..."));
    // LMIC init
    os_init();
    LMIC_reset();
    // Set static session parameters.
    LMIC_setSession (0x1, DEVADDR, NWKSKEY, APPSKEY);
    LMIC_setLinkCheckMode(0);
    LMIC.dn2Dr = DR_SF9;
    // Set data rate and transmit power for uplink (note: txpow seems to be ignored by the library)
    LMIC_setDrTxpow(DR_SF12,14);
    // Start job
    do_send(&sendjob, read_thermistor(readVal));
void loop() {
    os_runloop_once();
It does send an uplink packet but I can't see any data coming in to the console
(Somsak) #7
I might try to start with Arduino sketch generator here.
Somsak
(Nidaros) #8
This is very nice, but I'm using a different sensor and radio, will this still work?
radio: RFM96W (Using a Dragino shield)
sensor: dallas 18b20
(Nidaros) #9
I also have an analog temperature sensor btw
(Nidaros) #10
Tried the analog temperature sensor. I got some output on the TTN backend but it makes literally no sense. I have no clue at this point:
// MIT License
#include <lmic.h>
#ifdef CREDENTIALS
#else
static const u1_t NWKSKEY[16] = { 0xC7, 0x0B, 0xC7, 0xDA, 0x80, 0x44, 0x6A, 0x7A, 0xEF, 0x7B, 0x5A, 0x1B, 0x83, 0x0E, 0x4E, 0xF8 };
static const u1_t APPSKEY[16] = { 0x23, 0x85, 0xF6, 0x35, 0x5C, 0x8D, 0x21, 0x04, 0xB8, 0xD1, 0xCD, 0x81, 0x88, 0x7D, 0xFD, 0xD6 };
static const u4_t DEVADDR = 0x2601109D;
#endif
    .nss = 10,
    .rst = 9,
    .dio = {2, 6, 7},
void do_send(osjob_t* j){
    static uint8_t message[] = "hi";
    } else {
void setup() {
    // LMIC init
    os_init();
    LMIC_reset();
    // Start job
    do_send(&sendjob);
void loop() {
    os_runloop_once();
(Somsak) #11
I think RFM96W work with the sketch generator providing that your pin mapping is correct. What I have been tested so far is to use with my RFM95 and AM2320. Now, I am trying to find the way to reduce its power consumption.
(Nidaros) #12
I think its an RFM95, but it uses the RFM96W chip. Very confusing, you can look it up on the manufacturers site
(Nidaros) #13
UPDATE:
It works! (kinda) I received data for around half an hour.
// MIT License
#include <lmic.h>
#include <math.h>
#include <stdlib.h>
#ifdef CREDENTIALS
#else
#endif
    .nss = 10,
    .rst = 9,
    .dio = {2, 6, 7},
  double Temp;
   return Temp;
    Serial.println(F("Converting..."));
    dtostrf(val,2,0,outStr);
    Serial.println(outStr);
    uint8_t message[8];
    double temp = read_thermistor(readVal);
    convert_to_string(message,8,temp);
    } else {
        LMIC_setTxData2(1, message,2, 0);
//        LMIC_setTxData2(1, message, sizeof(message)-1, 0);
//        Serial.println(temp);
void setup() {
    // LMIC init
    os_init();
    LMIC_reset();
    // Start job
    do_send(&sendjob);
void loop() {
    os_runloop_once();
