# Alternative for iC880A antenna?
**URL:** <https://www.thethingsnetwork.org/forum/t/alternative-for-ic880a-antenna/1382>\
**Category:** Gateways\
**Created:** [March 2, 2016, 9:22am UTC](https://www.thethingsnetwork.org/forum/t/alternative-for-ic880a-antenna/1382 "2016-03-02T09:22:26Z")\
**Showing post:** 14
**Author:** ![Ideetron](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/ideetron/32/8829_2.png) [@Ideetron](https://www.thethingsnetwork.org/forum/u/Ideetron)\
**Post date:** [April 10, 2016, 12:13pm UTC](https://www.thethingsnetwork.org/forum/t/alternative-for-ic880a-antenna/1382/14 "2016-04-10T12:13:45Z")
If you get 250 meter range everything should be normal and nothing is fried.
You must have some real butterfingers to get the RFM95W fried, like working them on 12Vdc or something.
We are working with these modules for such a long time now and so far none have died on us yet.
If you have less than 80 meters range like James, then something in the RF path is wrong.
In your case I would have a look at the antennas and test again with 2x 1/2 wave center fed dipoles, like the ones I’ve suggested.
Put both in a high place (\>6 meter above ground) and test the Line Of Sight distance (no obstacles).
You should get 800 meter range easy.
Why the height of \>6 meters you ask?
This has to do with the Frenell Zone: [https://en.wikipedia.org/wiki/Fresnel\_zone](https://en.wikipedia.org/wiki/Fresnel_zone)
Calculate here: [http://www.wirelessconnections.net/calcs/FresnelZone.asp](http://www.wirelessconnections.net/calcs/FresnelZone.asp)
_[View the full topic](https://www.thethingsnetwork.org/forum/t/alternative-for-ic880a-antenna/1382)._
