Hi
I have tried to add a Adeunis temp module, I entered the correct DEV_EUI and APP_KEY into my application, I can se in the gateway trafic the the module try to join the TTN network but the module never goes online.
I have tried other Adueunis module with same result.
Did you use the Device EUI from the Adeunis device? If you opoen it up there’s a hexID you need to insert in your settings from the devices in your application.
I’m also struggling with getting a correct rerading in TTN.
I’m not able to get a a good decoder.
I see the HEX data come into the application of TTN but not decoded offcourse…
