# Best Gateway to buy \[ for a noob \]
**URL:** <https://www.thethingsnetwork.org/forum/t/best-gateway-to-buy-for-a-noob/47782>\
**Category:** Gateways\
**Created:** [May 17, 2021, 5:54pm UTC](https://www.thethingsnetwork.org/forum/t/best-gateway-to-buy-for-a-noob/47782 "2021-05-17T17:54:10Z")\
**Showing post:** 3
**Author:** ![pdonner](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/pdonner/32/35697_2.png) [@pdonner](https://www.thethingsnetwork.org/forum/u/pdonner)\
**Post date:** [May 18, 2021, 3:26am UTC](https://www.thethingsnetwork.org/forum/t/best-gateway-to-buy-for-a-noob/47782/3 "2021-05-18T03:26:10Z")
@pe1mew
> [@pe1mew](#):
> I would recommend a Mikrotik wAP 8
Are you a noob in router administration, as well? The kit contains router software, which can be tricky for a beginner. If you follow Remko’s recommendation, I would advise you to carefully read and consider ideas in MikroTik’s article: [Securing your router](https://wiki.mikrotik.com/wiki/Manual:Securing_Your_Router). MikroTik’s Omni antenna also offers good value. Remember to connect the antenna before booting the wAP 8. Also consult [MikroTik LoRaWAN gateways and concentrator boards](https://www.thethingsnetwork.org/forum/t/mikrotik-lorawan-gateways-and-concentrator-boards/27444) and [MikroTik Antenna Kit 6.5dBi](https://www.thethingsnetwork.org/forum/t/mikrotik-antenna-kit-6-5dbi/40420) on this forum.
_[View the full topic](https://www.thethingsnetwork.org/forum/t/best-gateway-to-buy-for-a-noob/47782)._
