Hello, I’ve recently registered about 100 devices using the TTN v3 API. Everything went fine and all the requests came back with success codes, but when I open the devices in TTN Console, none of them have the App Key field or session information and when I open the device network info the dashboard crashes. This is the script that I’ve used to register the devices. Are there any mistakes?
PS: The device name is always a string consisting out of 8 alphanumeric characters, all URL safe. Also, why isn’t there just a single endpoint?
const ttnHeaders = {
"Content-Type": "application/json",
Accept: "application/json",
Authorization: `Bearer ${process.env.TTN_KEY}`,
export async function createTTNDevice(deviceName: string) {
const app_eui = crypto.randomBytes(8).toString("hex").toUpperCase(); // Also called join_eui
const dev_eui = crypto.randomBytes(8).toString("hex").toUpperCase();
const app_key = crypto.randomBytes(16).toString("hex").toUpperCase();
const ids = {
join_eui: app_eui,
dev_eui: dev_eui,
device_id: deviceName.toLowerCase(),
application_ids: { application_id: "foo-network" },
const mainServerResponse = await fetch("https://eu1.cloud.thethings.network/api/v3/applications/foo-network/devices", {
method: "POST",
headers: ttnHeaders,
body: JSON.stringify({
end_device: {
ids,
network_server_address: "eu1.cloud.thethings.network",
application_server_address: "eu1.cloud.thethings.network",
join_server_address: "eu1.cloud.thethings.network",
const nsResponse = await fetch(
`https://eu1.cloud.thethings.network/api/v3/ns/applications/foo-network/devices/${deviceName.toLowerCase()}`,
method: "PUT",
end_device: {
frequency_plan_id: "EU_863_870",
lorawan_version: "MAC_V1_0_3",
lorawan_phy_version: "PHY_V1_0_3_REV_A",
supports_join: true,
multicast: false,
supports_class_b: false,
supports_class_c: false,
mac_settings: { rx2_data_rate_index: 0, rx2_frequency: "869525000" },
ids,
const asResponse = await fetch(
`https://eu1.cloud.thethings.network/api/v3/as/applications/foo-network/devices/${deviceName.toLowerCase()}`,
method: "PUT",
end_device: {
ids,
const jsResponse = await fetch(
`https://eu1.cloud.thethings.network/api/v3/js/applications/foo-network/devices/${deviceName.toLowerCase()}`,
method: "PUT",
end_device: {
ids,
root_keys: { app_key: { key: app_key } },
return { app_eui, dev_eui, app_key };
