# Can LMIC 1.6 be set up to use a single channel and SF?
**URL:** <https://www.thethingsnetwork.org/forum/t/can-lmic-1-6-be-set-up-to-use-a-single-channel-and-sf/5207>\
**Created:** [February 4, 2017, 10:43am UTC](https://www.thethingsnetwork.org/forum/t/can-lmic-1-6-be-set-up-to-use-a-single-channel-and-sf/5207 "2017-02-04T10:43:39Z")\
**Showing post:** 5
**Author:** ![mogyoros](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/mogyoros/32/25844_2.png) [@mogyoros](https://www.thethingsnetwork.org/forum/u/mogyoros)\
**Post date:** [April 15, 2017, 12:07pm UTC](https://www.thethingsnetwork.org/forum/t/can-lmic-1-6-be-set-up-to-use-a-single-channel-and-sf/5207/5 "2017-04-15T12:07:33Z")
Hi @itacos !
You are seeing the packet loss, beacuse in that case the node is trying to use the other base channels (frequencies: 868.3 & 868.5 MHz). Which you can’t disable using the lmic lib in this manner. I faced this issue aswell.
The only way is to modify the base channels/frequencies in the lib (lorabase.h, EU868\_F2&F3).
For the rest of channels/frequencies (3-8) you probably can manipulate this using LMIC\_setupChannel command.
We all now that this could violate the frequency usage (1%), and is not lorawan compliant, so shall careful doing so!
_[View the full topic](https://www.thethingsnetwork.org/forum/t/can-lmic-1-6-be-set-up-to-use-a-single-channel-and-sf/5207)._
