Hi everybody,
I am trying to configure an OTAA connection using as end-node STM Discovery L072z and an as a gateway a Dragino LG01-P. I am using ARM mbed OS to manage it and in particular I was trying to use the provided example of the platform, link.
Now, Dragino seems to be correctly set up as a gateway, while the end-node, even if I correctly copy and paste the DevEUI, the AppEUI and the AppKey (generated randomly with TTN) in the code that will be uploaded in the device, I am only receiving this output:
Mbed LoRaWANStack initialized
CONFIRMED message retries : 3
Adaptive data rate (ADR) - Enabled
e[2Ke[90m[DBG ][LSTK]: Initiating OTAAe[0m
e[2Ke[90m[DBG ][LSTK]: Sending Join Request …e[0m
e[2Ke[90m[DBG ][LMAC]: Frame prepared to send at port 0e[0m
e[2Ke[90m[DBG ][LMAC]: TX: Channel=0, DR=5e[0m
Connection - In Progress …
e[2Ke[90m[DBG ][LSTK]: Transmission completede[0m
e[2Ke[90m[DBG ][LMAC]: Opening RX1 Windowe[0m
e[2Ke[90m[DBG ][LMAC]: Opening RX2 Window, Frequency = 869525000e[0m
e[2Ke[90m[DBG ][LMAC]: TX: Channel=2, DR=4e[0m
e[2Ke[90m[DBG ][LMAC]: DC enforced: Transmitting in 5016 mse[0m
e[2Ke[90m[DBG ][LMAC]: TX: Channel=0, DR=3e[0m
e[2Ke[90m[DBG ][LMAC]: DC enforced: Transmitting in 14124 mse[0m
e[2Ke[90m[DBG ][LMAC]: TX: Channel=2, DR=2e[0m
e[2Ke[90m[DBG ][LMAC]: DC enforced: Transmitting in 30459 mse[0m
e[2Ke[90m[DBG ][LMAC]: TX: Channel=1, DR=1e[0m
e[2Ke[90m[DBG ][LMAC]: DC enforced: Transmitting in 75306 mse[0m
e[2Ke[90m[DBG ][LMAC]: TX: Channel=1, DR=0e[0m
e[2Ke[90m[DBG ][LMAC]: DC enforced: Transmitting in 140547 mse[0m
e[2Ke[90m[DBG ][LMAC]: TX: Channel=1, DR=4e[0m
e[2Ke[90m[DBG ][LMAC]: TX: Channel=1, DR=2e[0m
e[2Ke[90m[DBG ][LMAC]: TX: Channel=0, DR=1e[0m
e[2Ke[90m[DBG ][LMAC]: TX: Channel=2, DR=0e[0m
OTAA Failed - Check Keys
In the TTN console I don’t receive anything, except sometimes an activation message and then nothing else, not being able in download and upload messages.
Can someone help me understand why this doesn’t work? Thank all.
I attach the “Radio Settings” of my Dragino gateway.
