I can’t connect to TTN with my TTGO LoRa32_V2.1-1.6 board (lilygo)
I made an application using the TTN console where I configured:
- Europe SF9 freq plan (I am in belgium)
- filled in the device number that the device shows after reset
- appEUI set to all zeroes
- generated an appkey
- set LoRaWan version to 1.0.3
I copied those data to the lorawan-keys.h file OTAA data
After reset, I get the text below on the serial link.
The texts seems to show that it can’t connect, and on the console, I see no data appearing.
I tried inverting the appkey and device number (thinking problem might be endiannes), but that didn’t help.
Could it be that there is no signal? (I can’t make that out from the text below)
Or am I missing something else?
LMIC-node
Device-id: ttgo-lora32-v21
LMIC library: MCCI
Activation: OTAA
LMIC debug: 1
Interval: 60 seconds
RXMODE_RSSI
000000028656: Event: EV_JOINING
30507: engineUpdate, opmode=0x4
000000030548: doWork job started
139263: engineUpdate, opmode=0x4
000000139306: Event: EV_TXSTART
141260: TXMODE, freq=868100000, len=23, SF=7, BW=125, CR=4/5, IH=0
start single rx: now-rxtime: 2
457510: RXMODE_SINGLE, freq=868100000, SF=7, BW=125, CR=4/5, IH=0
rxtimeout: entry: 458033 rxtime: 457499 entry-rxtime: 534 now-entry: 3 rxtime-txend: 312375
520009: RXMODE_SINGLE, freq=869525000, SF=12, BW=125, CR=4/5, IH=0
rxtimeout: entry: 534357 rxtime: 519999 entry-rxtime: 14358 now-entry: 2 rxtime-txend: 374875
000000534383: Event: EV_JOIN_TXCOMPLETE
536613: engineUpdate, opmode=0x4
