# Can't Register Gateway, EUI is still in use
**URL:** <https://www.thethingsnetwork.org/forum/t/cant-register-gateway-eui-is-still-in-use/12161>\
**Category:** Raspberry Pi Gateways\
**Created:** [January 30, 2018, 1:53am UTC](https://www.thethingsnetwork.org/forum/t/cant-register-gateway-eui-is-still-in-use/12161 "2018-01-30T01:53:29Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Author:** ![PiXCL](https://www.thethingsnetwork.org/forum/letter_avatar_proxy/v4/letter/p/e0b2c6/32.png) [@PiXCL](https://www.thethingsnetwork.org/forum/u/PiXCL)\
**Post date:** [January 30, 2018, 1:53am UTC](https://www.thethingsnetwork.org/forum/t/cant-register-gateway-eui-is-still-in-use/12161/1 "2018-01-30T01:53:29Z")
</div>
Urgent, I cannot register the Gateway.
On the Registration page I get a message that says the EUI is still in use.
I had deleted my original account, and created a new account more in line with my work and thought I would be able to re-register the Gateway.
Can someone at TTN help me fix this problem.
The EUI in question is, 00:04:a3:0b:00:22:81:3c
I need this deleted so I can make the re-registration under my new account work.
Thank you so much for the help.
**Author:** ![pe1mew](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/pe1mew/32/48520_2.png) [@pe1mew](https://www.thethingsnetwork.org/forum/u/pe1mew)\
**Post date:** [January 30, 2018, 5:47am UTC](https://www.thethingsnetwork.org/forum/t/cant-register-gateway-eui-is-still-in-use/12161/2 "2018-01-30T05:47:12Z")
</div>
Try to contact TTN Noc trough Slack in #support
**Author:** ![htdvisser](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/htdvisser/32/45312_2.png) [@htdvisser](https://www.thethingsnetwork.org/forum/u/htdvisser)\
**Post date:** [January 30, 2018, 4:58pm UTC](https://www.thethingsnetwork.org/forum/t/cant-register-gateway-eui-is-still-in-use/12161/3 "2018-01-30T16:58:57Z")
</div>
Due to the long validity of (old) gateway access tokens, we can’t release gateway IDs to be registered by different users. If you still had access to your old account you could have transferred the ownership of the gateway to your other account, but if your old account is deleted, that will not work.
You could register your gateway under a different EUI, or you could register a human-readable GatewayID and use an MQTT forwarder to connect to TTN.
**Post date:** [January 30, 2018, 8:31pm UTC](https://www.thethingsnetwork.org/forum/t/cant-register-gateway-eui-is-still-in-use/12161/4 "2018-01-30T20:31:39Z")
</div>
Hello Hylke,
thanks for the fast reply. I do hope we can find a way to resolve this
issue.
> …Due to the long validity of (old) gateway access tokens, we can’t
> release gateway IDs to be registered by different users. … if your old
Reading the forum, we are not the only company, group or person to run into
this issue as we get familiar with the hardware and software. The way we
initially configured the package resulted in the gateway device never (so
far as we can tell) coming active.
To try and fix this, we deleted the original account, assuming, wrongly as
we found out, that this would also unregister the EUI. What we are now left
with is a ghost / orphan EUI and no obvious way to recover it other than
contacting TTN.
To be clear, we ARE NOT a different user, it’s the one and same Sandbox kit
with the same EUI.
> …register your gateway under a different EUI
I really don’t see how this can be a technologically valid option. My
understanding is that each gateway device has a unique EUI. Surely the last
thing TTN wants is people registering random EUI IDs that don’t align with
the hardware, or worse, duplicate other gateway nodes. Or have I missed
something?
If not, what do you suggest for the EUI? Change the last EUI hex digit?
Just make one up?
I’d need to be absolutely certain that the TTN server apps can handle a
different EUI and don’t query the hardware for the actual EUI and then
behave in an undefined manner.
Releasing our gateway ID so we can reregister it correctly would appear to
be the ideal and simplest solution for everyone.
So over to you. What can you do to solve this? What would you need from us
to do it?
**Author:** ![arjanvanb](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/arjanvanb/32/46626_2.png) [@arjanvanb](https://www.thethingsnetwork.org/forum/u/arjanvanb)\
**Post date:** [September 1, 2018, 10:37am UTC](https://www.thethingsnetwork.org/forum/t/cant-register-gateway-eui-is-still-in-use/12161/5 "2018-09-01T10:37:43Z")
</div>
Multi-posted to [Can't register Gateway - EUI is still in use](https://www.thethingsnetwork.org/forum/t/cant-register-gateway-eui-is-still-in-use/8952).
**Post date:** [September 1, 2018, 10:37am UTC](https://www.thethingsnetwork.org/forum/t/cant-register-gateway-eui-is-still-in-use/12161/6 "2018-09-01T10:37:49Z")
</div>
**Post date:** [September 1, 2018, 10:37am UTC](https://www.thethingsnetwork.org/forum/t/cant-register-gateway-eui-is-still-in-use/12161/7 "2018-09-01T10:37:54Z")
</div>
