Connected Hive
Hello everyone,
I started a year ago to develop a connected hive. The prototype I am currently working on, uses a Lora communication system through the things network to node red and finally the Blynk application
projet
Starting from my prototype, I developped a PCB with Kicad. In this PCB there is a ESP32 module, a RFM 95 lora, Deepsleep mode, load sensor with hx711, BME280 sensor and multiple DS18B20
3D lora node
My PCB is now working after some time spend on it!
lorawan lorawan1 lorawan2
christophe
Quite interesting! Would you share some more details about this project? I mean code, PCB, …
Hi, just wondering why you’re monitoring the hive. What information are you getting out of it?
one of the most information I need is the weight and also the internal temperature.
I believe if u also use a mic to monitor frequency and volume this can give early warning if about to swarm :wink:
