# Connecting TTIG to The Things Stack (TTN V3)
**URL:** <https://www.thethingsnetwork.org/forum/t/connecting-ttig-to-the-things-stack-ttn-v3/43363>\
**Category:** V3 Gateways\
**Created:** [January 28, 2021, 12:28am UTC](https://www.thethingsnetwork.org/forum/t/connecting-ttig-to-the-things-stack-ttn-v3/43363 "2021-01-28T00:28:37Z")\
**Showing post:** 110
**Author:** ![Jeff-UK](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/jeff-uk/32/35697_2.png) [@Jeff-UK](https://www.thethingsnetwork.org/forum/u/Jeff-UK)\
**Post date:** [June 30, 2021, 3:23pm UTC](https://www.thethingsnetwork.org/forum/t/connecting-ttig-to-the-things-stack-ttn-v3/43363/110 "2021-06-30T15:23:25Z")
Ok, So here comes the 1st IDIOT\_Test™ (i.e. me!) of the console claiming method
_TL::DR - It just works!_ 🙂
_Updated to add explicit separate link to instructions originally posted by Hylke above now available on a new thread here…note caution wrt gw’s bought via [IoT-shop.de](http://IoT-shop.de) and/or Amazon_.
### [Move your TTIG to V3: YES!](https://www.thethingsnetwork.org/forum/t/move-your-ttig-to-v3-yes/49287)
Had one TTIG left in lab where I had access to WiFi code so it became guinea pig. Initially registered in V2 as Genesis-S3\_TestGW036\_TTIG\_…(additional info in description) and ran happily for a long time with 100’sk (M’s?) uplinks trafficked.
 ![image](https://www.thethingsnetwork.org/forum/uploads/default/original/3X/c/6/c654237fa961fe656e817ff32f6c165cf00b8dbd.png)
The only inconvenience was fact I like to list/describe GW’s using format Entity\_DeviceID\_Type\_Config\_Location disclaimer etc.
and it would have been nice to use part as GW ID - but rather system requires lowercase, numbers and dashes only (@descartes - you know me and my mixed case ID’s 😉 )
Not a problem as general settings allow more (later)
Successful claim/V3 registration:
 ![image](https://www.thethingsnetwork.org/forum/uploads/default/original/3X/9/5/9561d0738b997260944c31f00cda34df5711bc21.png)
General Settings were a bit more Jeff friendly wrt info input & use/format:
 ![image](https://www.thethingsnetwork.org/forum/uploads/default/original/3X/1/5/15774c7642067e6d62f4c3dc87951863785309d7.png)
A quick power cycle for GW to get new settings and V3 registration and ~2 mins later we have traffic 🙂
 ![image](https://www.thethingsnetwork.org/forum/uploads/default/original/3X/e/e/eeba2ebf5c2026477dc214503559ac0544d5052e.png)
With GW showing in my TTS(CE) aka TTN V3 GW list as connected 🙂
 ![image](https://www.thethingsnetwork.org/forum/uploads/default/original/3X/e/f/efac98bad9da856ff7721ab68743442229d83cd5.png)
A quick check in V2 console and whilst it still shows as connected (guess that data will update and age over coming minutes and hours \*_update - now shows as 'unknown_’) all data looks to have disappeared and now offline. Only issue is I forgot the vanity grab of handled statistics (uplink/downlink count - think this one had hit \>2M uplinks)
 ![image](https://www.thethingsnetwork.org/forum/uploads/default/original/3X/3/f/3f83c97fd7bf9a53d1c2c46458147d3d0ccfa3e8.png)
**So…_RESULT!_** 🍾 🎆
_[View the full topic](https://www.thethingsnetwork.org/forum/t/connecting-ttig-to-the-things-stack-ttn-v3/43363)._
