Console says "Disconnected, try to reconnect"
(Basvaningen) #1
My TTN Console says "Disconnected, try to reconnect".
Tried login on different pc's. What's the problem??
Does a refresh help, or is it always disconnected?
cc @romeovs
(Basvaningen) #3
Hi Johan,
A refresh does not help, even logging in on a different workstation doesn't work.
(Mimite) #4
I am having the same issue
A connection to one of the backing services was misbehaving. I restarted the console and this mitigated the issue. Will investigate why this happened.
Thanks for the report!
(Basvaningen) #6
@romeovs the problem looks solved. But now i have another problem. I can't see any application data anymore. The node data stays empty. But on the gateway i can see the massages beeing forwarded. 22 minutes ago it was working.
(Thomasn) #7
Is this problem back again? I can't get the console working. It keeps saying 'disconnected, try to reconnect'. Reconnecting doesn't work, logged in & out,...
Me too :sweat:
