Create a class C node
(Aayk) #1
I have used a Multitech Conduit gateway and an Adafruit Feather 32u4, and used the LMIC library to uplink and downlink successfully. Actually the Adafruit Feather is working like a class A node, but I am searching to implement a class C node. I have searched for many days but I have not found anything. Could you help me?
(Wero1414) #2
Hey naayak here i have one gist where i put the RFM95 into class c mode but the code is no user friendly for change the data rate and the spread factor or the frequency, im using the just the SPI library and all the communication its done by functions included in the sketch
(Aayk) #3
Thank you very much. I will try it
