Decoding node messages in ttn backend
(Toomany Secrets) #21
Ok this is the test with a real sensor.
The data im sending to ttn is this 000A34 this is Temperature: 26.12
Can anyone help me decode it in ttn backend ?
This code is what i am using.
https://pastebin.com/vRqgCmwe
#22
use the following Payload Function to decode it in console:
function Decoder(bytes) {
var temp = (((bytes[1] << 8) | bytes[2])/100 ).toFixed(2);
return {
Temp : (temp),
(Toomany Secrets) #23
Thx man. Worked perfectly. If you have time can you explain the code so i know how to do it myself in the future.
#24
search for "payload function" in forum, there is for example:
https://www.thethingsnetwork.org/forum/t/decoding-a-float-value-in-a-payload-function/4395/12 which even has a nice youtube video explaining exactly what you need : decoding payload
(Arjan) #25
That won't work for negative values.
See Is there any documentation on payload functions? for some references.
(Toomany Secrets) #26
How would i make this work for negative values?
Anyone can help out with code?
(Arjan) #27
Well, I just gave you a link which you don't seem to have clicked, and it is also explained in the first link in the answer before mine.
(Toomany Secrets) #28
I did click it, but i have no idea on were to start. I never worked around with javascript. Im asking for the code outright if anyone can help.
I managed to do the arduino code but is is just way over me. Im just looking to set up some sensors at my weekend house and lake.
(Nidaros) #29
add +100 to your value in the arduino script and -100 in your decoder. Should do, unless you want to monitor hotter things lol
