# Downlink Freq RX2 // 869.525
**URL:** <https://www.thethingsnetwork.org/forum/t/downlink-freq-rx2-869-525/7144>\
**Category:** Gateways\
**Created:** [May 8, 2017, 12:06pm UTC](https://www.thethingsnetwork.org/forum/t/downlink-freq-rx2-869-525/7144 "2017-05-08T12:06:15Z")\
**Showing post:** 2
**Post date:** [May 8, 2017, 12:39pm UTC](https://www.thethingsnetwork.org/forum/t/downlink-freq-rx2-869-525/7144/2 "2017-05-08T12:39:02Z")
TTN indeed uses 869.525 with SF9 and 27 dBm high transmission power for RX2, and in the early days preferred RX2. However, [nowadays it prefers RX1](https://www.thethingsnetwork.org/forum/t/why-is-rx-slot-1-not-used/2656/5):
> [@Gateway Latency](https://www.thethingsnetwork.org/forum/t/gateway-latency/6942/3):
> We try to avoid RX2 if possible. For RX1 we have 8 channels available, while RX2 is fixed on 1 channel and a very inefficient data rate. Therefore, expect most downlink messages to be sent after 1 second.
RX1 uses the same settings as your last uplink, and regular 14 dBm transmission power. So, despite the title of your post, I assume you’re seeing RX1 in the last two examples above (and indeed RX2 in the first example).
_[View the full topic](https://www.thethingsnetwork.org/forum/t/downlink-freq-rx2-869-525/7144)._
