se-bk
(Se Bk)
May 29, 2023, 7:00pm
1
a Dragino DLOS8 is connected (online) i see in the console status packets but there are no upload packets.
Blockquote
“name”: “gs.status.receive”,
“time”: “2023-05-29T19:01:09.576820495Z”,
“identifiers”: [
“gateway_ids”: {
“gateway_id”: “xxxxxxxxxx”,
“eui”: “A84041xxxxxxxx”
“data”: {
“@type ”: “type.googleapis.com/ttn.lorawan.v3.GatewayStatus ”,
“time”: “2023-05-29T19:01:09Z”,
“versions”: {
“ttn-lw-gateway-server”: “3.25.1-SNAPSHOT-414e327a2”
“antenna_locations”: [
“latitude”: xx.5683,
“longitude”: x.30237,
“altitude”: 70,
“source”: “SOURCE_GPS”
“ip”: [
“185.xxxxxxxxx”
“metrics”: {
“rxfw”: 0,
“ackr”: 99.6,
“txin”: 0,
“txok”: 0,
“rxin”: 0,
“rxok”: 0
“correlation_ids”: [
“gs:conn:01H16CE9150NQ2GM5C03KF78YJ”,
“gs:status:01H1ME5ET8THYKXSP81H51SYTK”
“origin”: “ip-10-100-4-135.eu-west-1.compute.internal”,
“context”: {
“tenant-id”: “CgN0dG4=”
“visibility”: {
“rights”: [
“RIGHT_GATEWAY_STATUS_READ”
Blockquote
What can be the problem?
Where can i find a description of the status message?
Greetings
E_T
descartes
(Nick McCloud)
May 29, 2023, 7:46pm
2
Do you have a device uplinking? (probably yes, given your other topic).
The documentation is linked bottom right of every single console page.
However as you note, they are status updates, aka gateway alive, so it tells you that stats.
You’ve redacted the EUI which is public information and the location, which is public information, but not the IP address …
Please review your use of the </> tool to make sure it worked before posting - the preview is on the right of the message box. Cheers.
se-bk
(Se Bk)
May 30, 2023, 9:32am
3
Thank you for your answer.
So in the console there were same counts of uplinks (see picture), but there are no uplings from the devices and i testet the gateway with a ttn-mapper device, no packets comes from the Gateway.
I’m sure packages were also received during the setup at the table. Now in active operation in another network it does not work. Are status messages also forwarded if, for example, port 1700 is blocked by a firewall?
Greetings
E_T
where are your gateway located, indoor, outdoor
se-bk
(Se Bk)
June 1, 2023, 3:11pm
5
The Gateway is located outdoor, during a test one identical Gateway is placed near the same position but this Gateway had a LTE-connection.
