Dragino gateway
(Ecabanas) #1
Hi all,
I just bought a dragino Lora gateway and I want to know if somebody knos how to configure to connect to TTN server.
Thank's in advance
LG01-P dragino
this one ?
(Ecabanas) #3
I'm sorry, but I could not find the info, my dragino is not a hat is this gateway:
somebody has to write new firmware and recompile I guess .. but its still a single channel gateway
(Ecabanas) #5
When you said single channel, is not useful for receive data from one node?
yes that's possible.. this gateway can receive a LoRa signal from a node, but I don't know how to connect this 'gateway/lora receiver' to TTN.
if they mean by IOT server a LoRaWAN connection ...
I see they have a kit
(Ecabanas) #7
ok, if you know, please tell me, ok?
(Jose Marcelino) #8
This "gateway" is an Arduino (ATMega328P) + Sx1276 connected to a OpenWRT router over serial.
You can't use this with TTN other than as node. Personally I think Dragino is conning users by calling this a gateway.
they sell it as an LORA gateway .. not a LoRaWAN gateway.
I think it's an interesting product.. might buy one actually :sunglasses:
(Jose Marcelino) #10
Seriously a Raspberry Pi with a LoRa shield is a lot more flexible, better and cheaper than this product.
In any case whatever you do don't waste your money on the OLG01 "outdoor" version. It's a piece of junk and not remotely outdoor ready.
(Jose Marcelino) #12
This is quality you can expect in the "outdoor gateway"
Plugs not fitting properly, holes look like they were made with a soldering iron (melted plastic around the edge).
Amateur hour.
(Fspr) #14
this link is supposed to provide information
(Arjan) #15
Wow, even their own sales image shows the soldering iron holes, with brown burn marks (and a different position of the antenna connector).
(Fspr) #16
I have it connected to ttn
Look at thr wikipedia page
(Dridi93) #17
Hi ,
Does it show that the data has been recieved or only that it is connected ? in my case I have been trying to connect a node with this type of Gateway, but it only show that it is connected with no messages recieved.
(Fspr) #18
So far only connected. No packets recieved in the webpage!
(Fspr) #19
Need to check the channel they operate on!
(Dridi93) #20
I am in the same situation, I am losing hope that this thing works with TTN, sigh..
(Ameisina) #21
We have made a video with a simple example to show how to connect the dragino lora gateway to TTN.
Here is the link: https://youtu.be/Egm6LAlvNAs
