DRAGINO problems and solutions topic part 1
Now, I’ve got the code working. The point is that in global_conf.json you have to set pin_rst to 3 instead of 0 as in README.md. Pins for Dragino hat are:
"pin_nss": 6,
"pin_dio0": 7,
"pin_nss_2": 6,
"pin_dio0_2": 7,
"pin_rst": 3,
The other pins can remain untouched.
As Dragino hat has only one RFM95 module you will get a single channel gateway, not a dual channel gateway (with up- and downlink). Therefore you have to comment out line 552 in LoraModem.c:
// Die("Unrecognized transceiver");
After that the GW will work fine.
