Gateway in network
(Gerardvtk) #1
Last week I connected a gateway in a network and the IT department had the following question: what kind or protocol is used by this Semtech TTN gateway, how secure is it? Do you guys have more information on this? So for the next connection I can prepare some documentation. You know how it is to put a new device in a “big” network.
#2
that’s not very much info … dragino ?
(Gerardvtk) #3
excuse me. No no, this gateway was the Multitech Conduit ( ethernet). thank you.
(Don Hege) #4
But what is the exact question? What protocol the Gateway is using to connect to the Backend?
(Gerardvtk) #5
Okay, I am not an IT expert. But my question is: somebody puts a gateway in a internet network ( at home or for a company) The gateway will have the contact with TTN and there is a information exchange between the gateway in the local network and the TTN backend.
But the problem is solved, I just found this page: https://www.thethingsnetwork.org/wiki/Backend/Home
I thinks will information will cover the most questions. thanks
discussion can be closed
#6
