Hello guys,
I have a request regarding the meta data of an end device.
Would it be possible to sort the gateways in terms of ‘weakest’ to ‘strongest’ in the metadata of each end device?
This would be very convenient if you forward your data with a web hook to a 3rd party server application. In this way filtering the JSON data will be easier and if you’re interested in the strongest you will pick the top (or bottom) of the sorted gateways, instead of interpret the snr / rssi numbers.
Thanks in advance
Best regards,
Albert
