# Gateway problem
**URL:** <https://www.thethingsnetwork.org/forum/t/gateway-problem/41653>\
**Category:** Uncategorized\
**Created:** [November 26, 2020, 7:50am UTC](https://www.thethingsnetwork.org/forum/t/gateway-problem/41653 "2020-11-26T07:50:38Z")\
**Posts on this page:** 7\
**Page:** 1
<div class="post-metadata">
**Author:** ![daviddu08](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/daviddu08/32/38658_2.png) [@daviddu08](https://www.thethingsnetwork.org/forum/u/daviddu08)\
**Post date:** [November 26, 2020, 7:50am UTC](https://www.thethingsnetwork.org/forum/t/gateway-problem/41653/1 "2020-11-26T07:50:39Z")
</div>
Hi all
I have a problem since this morning.
yesterday my gateway was ok on ttn and this mornig ttn say : Gateway offline. but when i connect on gateway by wifi, all is ok, network test ok.
TTN is having problems right now ?
Thanks for help
**Author:** ![mikebargauan](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/mikebargauan/32/35697_2.png) [@mikebargauan](https://www.thethingsnetwork.org/forum/u/mikebargauan)\
**Post date:** [November 26, 2020, 8:03am UTC](https://www.thethingsnetwork.org/forum/t/gateway-problem/41653/2 "2020-11-26T08:03:28Z")
</div>
I am experiencing similar problem - gateway is “Not connected” but devices are showing data traffic !!
Yesterday was ok, traffic on gateaway ok, problem started this morning.
**Post date:** [November 26, 2020, 8:08am UTC](https://www.thethingsnetwork.org/forum/t/gateway-problem/41653/3 "2020-11-26T08:08:18Z")
</div>
yes exactely same here.
I just spent 1 hour dismantling my 8 meter mast to check my gangway and everything is ok …
**Author:** ![cultsdotelecomatgmai](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/cultsdotelecomatgmai/32/35697_2.png) [@cultsdotelecomatgmai](https://www.thethingsnetwork.org/forum/u/cultsdotelecomatgmai)\
**Post date:** [November 26, 2020, 9:06am UTC](https://www.thethingsnetwork.org/forum/t/gateway-problem/41653/4 "2020-11-26T09:06:53Z")
</div>
Hi @daviddu08, looks like YANOCO strikes again.
Yet Another NOC Outage.
My gateways are showing not connected.
My data is all flowing just fine via MQTT.
As the HitchHiker’s Guide says: DON’T PANIC.
Do not power-cycle, re-flash, etc. your gateways or rip them off the roof and throw them in the trash.
**Author:** ![pieterhoenderken](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/pieterhoenderken/32/35697_2.png) [@pieterhoenderken](https://www.thethingsnetwork.org/forum/u/pieterhoenderken)\
**Post date:** [November 26, 2020, 10:01am UTC](https://www.thethingsnetwork.org/forum/t/gateway-problem/41653/5 "2020-11-26T10:01:10Z")
</div>
Over here in Doetinchem the same problem. Gateways say that they are connected, but in the console I don’t see any gateway connected
**Author:** ![descartes](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/descartes/32/47220_2.png) [@descartes](https://www.thethingsnetwork.org/forum/u/descartes)\
**Post date:** [November 26, 2020, 10:09am UTC](https://www.thethingsnetwork.org/forum/t/gateway-problem/41653/6 "2020-11-26T10:09:15Z")
</div>
You may wish to review this:
> [@TTN V2 Console not working properly all the time](https://www.thethingsnetwork.org/forum/t/ttn-console-not-working-properly-all-the-time-console-gateway-not-connected-no-traffic-application-no-data/37915):
> The TTN Console is not working properly all the time The following issues can manifest: Gateway is shown in TTN Console as ‘not connected’ or e.g. ‘last seen 1 days ago’ while the gateway is actually connected. The disadvantage of this is that the TTN Console gateway status is unreliable and that the gateway Traffic cannot be monitored in the console. TTN Console shows no Data for an application and/or its devices, while the application actually does receive data from devices. The disadv…
And also consider making yourself a little canary device so you can automagically monitor from device through to your dashboard.
**Post date:** [November 26, 2020, 10:09am UTC](https://www.thethingsnetwork.org/forum/t/gateway-problem/41653/7 "2020-11-26T10:09:36Z")
</div>
