# Gateway problem
**URL:** <https://www.thethingsnetwork.org/forum/t/gateway-problem/41653>\
**Category:** Uncategorized\
**Created:** [November 26, 2020, 7:50am UTC](https://www.thethingsnetwork.org/forum/t/gateway-problem/41653 "2020-11-26T07:50:38Z")\
**Showing post:** 6
**Post date:** [November 26, 2020, 10:09am UTC](https://www.thethingsnetwork.org/forum/t/gateway-problem/41653/6 "2020-11-26T10:09:15Z")
You may wish to review this:
> [@TTN V2 Console not working properly all the time](https://www.thethingsnetwork.org/forum/t/ttn-console-not-working-properly-all-the-time-console-gateway-not-connected-no-traffic-application-no-data/37915):
> The TTN Console is not working properly all the time The following issues can manifest: Gateway is shown in TTN Console as ‘not connected’ or e.g. ‘last seen 1 days ago’ while the gateway is actually connected. The disadvantage of this is that the TTN Console gateway status is unreliable and that the gateway Traffic cannot be monitored in the console. TTN Console shows no Data for an application and/or its devices, while the application actually does receive data from devices. The disadv…
And also consider making yourself a little canary device so you can automagically monitor from device through to your dashboard.
_[View the full topic](https://www.thethingsnetwork.org/forum/t/gateway-problem/41653)._
