Generic node
Hello
Is good things
Can you shared us the GitHub of this project?
genericnode
I can’t find anything on Github, but there is a site where we can sign up to join the early access program: https://www.genericnode.com/
Just smiling to myself, looks like it is overreaching on some promises (but you never know) - clicked on the forum link and it brings you back to here :slight_smile:
Any word on pricing? I’m trying to understand what appears to be a weather-proof enclosure around a light sensor, touch sensor, and temperature sensor. Those don’t seem all too useful unless you have some very small users that can fit inside that enclosure :smiley:
generic
25 USD in medium volume.
Light: The prototype shown on The Things Conference has a semi-transparent front that would let light through. (see my photo below)
Touch: Touch works through plastic. I have built a device that uses a touch sensor behind 1mm plastic. Many modern smart phones with touch support are weatherproof.
Temperature: Plastic does not block heat, so sensing temperature is no problem.
DSC05272-HDR
wow :open_mouth:
Wow indeed! That clears up all the question I had, thanks for that photo and the insight!
Any planning regarding this ?
Called competition, the high pricing of some devices is purely profiteering from a lack of competition and what is needed is a major shake up like this.
generic node at 40:00
  • for every sensor build in there is a free program.
  • you can upload these programs wireless, you can edit them
  • you can write your own… and SHARE solutions / code
wow… this will give a lot of new possibilities imho … can’t wait :sunglasses:
It’s all gone a bit quiet here - any update on progress?
Again this is called out for future RS supply chain…will it be like the TTN/TTI Outdoor GW with other preferred(?) vendors getting 1st dibs/early access as recently happened with ConnectedThings?
The generic node seems to be a great piece of hardware!
Any news about its availability so far?
Is there a release date available?
2019? Q2? Q3?
Is this baked via a kickstarter program?
Is there a way of getting early access?
Greetings from Europe! :slight_smile:
no need to ask… if information was available you would read it here directly.
greetings back
I assume it’s capacitive touch, so yes, no problem for the sensor to be covered by plastic.
Hello! Sign-Up for early access fails on FF/Linux. Chrome works. Greetings!
