Get noise level from IC880a
#1
Is it possible to read the noise level (RSSI while nothing received) from an IC880a?
This would be a nice value to check if there are any external interferers (higher noise level) or a perhaps a defect preamp-IC (lower noise level).
(Cslorabox) #2
That’s actually a very interesting question. I suggest you change the title to be generic to any SX1301 based non-FPGA solution.
The fact that https://github.com/Lora-net/lora_gateway/blob/master/util_spectral_scan/src/util_spectral_scan.c uses the add-on SX127x in a V2 FPGA concentrator suggests that there may really not be a way to do this with the SX1301, even as a diagnostic while not trying to operate as a concentrator.
SX1301 data sheet has very little information about capabilities - it lists an RSSI register but doesn’t really say if there’s a way to get a reading there other than via the packet receive engine. Most of the actual published information seems to be in the Semtech interface library source itself.
