How to get DevEUI for Arduino Uno?
(Hashim95) #1
Hi all,
I am following this guide to create my first TTN Node based on the Arduino Uno.
https://www.thethingsnetwork.org/forum/t/how-to-build-your-first-ttn-node-arduino-rn2483/1574
I have come to the stage where I should create an application and setup my device. I am however unsure on how to obtain my DevEUI. I tried using the in built example, but Serial1 is invalid for the Arduino Uno, and only available on the MEGA.
Any ideas or help would be much appreciated!
Kind regards,
Hashim
#2
Would this help?
#3
Hi Hashim
Try using the example for the Arduino Uno/Nano:
At startup it will print the Device EUI on the normal Serial, which is connected to your computer.
(Hashim95) #4
Thanks, got my DevEUI from this :slight_smile: One question about this code though, I am following steps from your document:
When I try using ABP, I keep getting the error code:
"expected primary expression before addr"
I commented out parts of your code appropriately (I think?) so it looks like this:
ABP: initABP(String addr, String AppSKey, String NwkSKey);
join_result = myLora.initABP("9795A671", "0C23D43078ED1854588BD01612835474", "E3187F1C65FDD39A42DDFFBE716C0725");
Do you know what I am doing wrong? Thank you!
#5
The first line starting with ABP: is a comment line describing how the line after it should be used. Do not remove the // in front of it.
//ABP: initABP(String addr, String AppSKey, String NwkSKey);
(Hashim95) #6
Sorry for the delay in response, I have only just seen your message.
Doh! Can't believe I was doing that wrong all this time, thanks for the help :slight_smile:
