# Issues with Things Uno OTAA Connection
**URL:** <https://www.thethingsnetwork.org/forum/t/issues-with-things-uno-otaa-connection/18040>\
**Category:** Hardware\
**Created:** [September 20, 2018, 8:10am UTC](https://www.thethingsnetwork.org/forum/t/issues-with-things-uno-otaa-connection/18040 "2018-09-20T08:10:23Z")\
**Showing post:** 6
**Post date:** [September 23, 2018, 9:18am UTC](https://www.thethingsnetwork.org/forum/t/issues-with-things-uno-otaa-connection/18040/6 "2018-09-23T09:18:34Z")
> [@Barlin1](#):
> my node’s signal is only being picked up by a gateway which is further away than gateways which I know are closer and I know are using the same frequency plans.
So those are not single-channel test gateways? If they’re full gateways, then still their range might be shorter (from some direction) simply due to their position. Like: surrounding buildings, antenna height, and when they’re installed inside, maybe even behind insulating glass.
> [@Barlin1](#):
> How does spreading factor effect this
A proper node should perform frequency hopping: it should randomly use a different frequency for each uplink (at least in EU868). But it will only change its SF to improve its reach.
Single-channel test gateways often listen to a single frequency, on a single SF. Like Kersing wrote:
> [@kersing](#):
> You ‘gateway’ is Dragino LG01 which is a single channel ‘gateway’. Is your node transmitting on the frequency and spreading factor your gateway is set to? If not it will never receive the transmissions.
Some single-channel test gateways listen on multiple SFs for their single frequency, but then their reception range is decreased [due to using CAD](https://github.com/JaapBraam/LoRaWanGateway/blob/master/README.md#how-multiple-spreading-factors-are-detected).
Full gateways are ready to receive on all frequencies and SFs of a given frequency plan.
> [@Barlin1](#):
> is there a way to ‘sync’ a node to the same spreading factor as the closest gateway?
Not automatically. You could implement sending confirmed uplinks and keep track of which frequency and SF works. But that feels like a huge waste of time to be able to use test gateways, especially as the number of gateways could change any time. Also, you’re [limited to 10 confirmed uplinks per day](https://www.thethingsnetwork.org/forum/t/limitations-data-rate-packet-size-30-seconds-uplink-and-10-messages-downlink-per-day-fair-access-policy/1300/80).
For testing, if you know some gateway’s settings, see [How to make RN2483 node use a fixed channel and spreading factor?](https://www.thethingsnetwork.org/forum/t/how-to-make-rn2483-node-use-a-fixed-channel-and-spreading-factor/2156)
_[View the full topic](https://www.thethingsnetwork.org/forum/t/issues-with-things-uno-otaa-connection/18040)._
