Lack of gateway, how to test a sensor node?
(Hashim95) #1
Hi all,
I built my first TTN node according to this:
My main issue is that where I live there is no gateway present. In your experience, what is the best way to test my new node in this situation? I think I will need to either buy a gateway, build my own, or travel to the nearest gateway. I would avoid building one due to time constraints on this project!
Could you guys give me any tips? What are the current cheapest gateways out there?
Kind regards,
Hashim Shamsi
#2
I had the same problem and I started by traveling to the nearest gateway.
After that I developed a single channel gateway that I use to develop and test my nodes. It is cheap and can do uplinks, downlinks and OTAA.
(Hashim95) #3
Ah sounds great! Unfortunately I get a 404 not found on that link? I read somewhere that The Things Network does not support single channel gateways either. Is this not the case then? Or did you test in ways other than TTN?
#4
I have no idea where you live exactly, but perhaps there’s a TTN meetup near you?
For example: https://www.meetup.com/Internet-of-Things-Utrecht/events/237171452/
People at a TTN meetup can usually help you to check your software settings etc, and there might even be someone that can bring their gateway with them if you ask nicely.
