Hi everyone!
I did a node with an arduino uno and a rfm95w and im sending data really well, also to cayenne page, but im getting some difficulties in downlinks.
I´m thinking that my pin mappin isnt good enougth to Rx messages node maybe?
Modify your node firmware to print out when it operates the radio in receive mode, and with what settings. Compare this to transmit logs of your gateway.
what should i modify on my node firmware for do what you are saying? I modify something like LMIC_DEBUG_LEVEL from 0 to 1 in the config.h library of LMIC… but nothing changed in my node serial monitor. Should i do something more?
You’ll have to take time to understand your node firmware to find good places for debug code. As a guess for LMiC try printing out frequency, spreading factor, etc in the RADIO_RX case in radio.c, ideally do it after it starts the receiver but before waits to see if there is a result, so that the printing doesn’t mess up the timing
