LoPy: micro-python LoRaWAN nano gateway board with WiFi/BLE
#1
The LoPy Kickstarter campaign will launch tomorrow. Basically this board can be configured as a Node or as a "nano" Gateway supporting up to 100 Nodes itself. Runs micro-python, combines LoRa with Wifi and Bluetooth in the one package and is from the same stable that created the WiPy. Its incredibly cheap at only €48 with an antenna.
You can preview the campaign here (I am not affiliated):
LoPy Kickstarter preview link
The LoPy on The Things Network
#2
Seems, Great!
#3
Nice project, just keep in mind the nano gateway is not LoRaWAN compliant, just like the single channel gateway based on RPi is not compliant.
Also a node range of up to 40 km is very optimistic.
Class C support is nice. :smile:
#4
Fantastic video guys, well done :smile:
...any chance you could squeeze in an NFC reader?
#6
Interesting but no LoraWan on board?
I also think this is a bold statement if you talk about range. With good antenna's and the RN2483 chip we had 3 km. range in non urban areas.
Cheers.
(aakash tewari) #7
Its on. Back it for early starters.
#8
The LoPy Kickstarter campaign is now live:
LoPy on Kickstarter
#9
Indeed, and twinkits are going fast (got one :smile: )
#10
Just to be clear, this can be used out of the box with TTN?
(Gonzalo Casas) #11
In theory, yes. They claim they'll pass the LoRaWAN certification program
#12
Interesting.
#13
Nice board. Would have liked a Nordic or STM based Cortex M but this is way better than the silly AVR and PIC based stuff that is out there, so I backed the KS.
#14
Today received my LoPy Twinkit Kickstarter reward :yum:
Tried to use it on TTN using the LoRaWAN example on the pycom site but it didn't work out yet. Of course I adapted the AppKey, AppEUI, DevEUI (MSB)
The staging backend shows that the device was activated, so I guess a Join Request was received. However it stays put while waiting for the join reply on the node.
while not lora.has_joined():
    pass
I did update to the latest firmware version:
os.uname()
(sysname='LoPy', nodename='LoPy', release='0.9.0.b2', version='f5444c7 on 2016-10-12', machine='LoPy with ESP32')
Anyone having success with their brand new LoPy?
#15
Hi, been testing my LoPys with the same approach as you but with a locally deployed TTN backend. Same issue arose, join was accepted but the LoPy itself would not complete the join. I alerted the Pycom team on Friday and they are working on identifying the issue with TTN and fixing it... will let you know as soon as I hear. We run Kerlink gateways with the simple packet forwarder.
#16
LoPy is aware of the join issue and we're working with them to find out what the issue. Once resolved and further documented, we'll publish a guide on using LoPy with TTN.
#17
Thx @jmgurgeh, @fokkezb.
How about using ABP?
If we know the format for the auth tuple for activation=LoRa.ABP we can try that .
As ABP is a lot simpler because as no downlink messages are involved, maybe that works already?
As I want to use a LoPy for tracking / coverage measurements I prefer to use ABP anyhow.
#18
@Batilan ABP has just been enabled in the latest LoPy firmware update issued last night.
I won't have chance to test this myself till Monday, but if you do before then, could you post how you get on?
#19
And I see @kruisdraad has posted a working example on this forum and on the pycom forum :smile:
Well sort of working....
Remember to update to the latest firmware version.
(Vseta) #21
Does Lopy Work ok? I've considered buying them, but I keep coming across posts regarding bugs and weak firmware support. What's the deal?
