LoRa Frequency in India
(Durvesh 09) #1
Can i use Microchip’s RN2483 (868MHz) in India by changing its frequency to 866 or 867 MHz ?
Is it possible to change the operating frequency below 868MHz ?
(Hylke Visser) #2
You can use your RN2483 in 863-870 MHz
(Durvesh 09) #3
ok… do you know how to configure microchip rn2483 for 865MHz operation ?
#4
How to build your first TTN node arduino + RN2483
(Hylke Visser) #5
I’m sure you can find everything you need in the documentation of the module. Just search for “RN2483 command reference”, download the PDF and search for “set channel frequency”.
(Durvesh 09) #6
Thanks @htdvisser, @rish for the help…
