LoRaWAN Academy - AWS stack error
Looks you the ThingType has been deprecated on your account. This might be due to the integration failing during clean up correctly or a manual action.
Go to Manage > Types > lorawan > Action (right - top) > Undeprecate.
Hope it helps.
Best
Dear Johan,
I might be wrong but I’m failing to execute the AWS IoT integration as I’m experiencing a similar problem to others; the version of Go referenced in the CloudFormation template is possibly not current on AWS and it fails with the following message:
“No Solution Stack named ‘64bit Amazon Linux 2018.03 v2.11.0 running Go 1.12.1’ found. (Service: AWSElasticBeanstalk; Status Code: 400; Error Code: InvalidParameterValue; Request ID: d7”
AWS indicate “64bit Amazon Linux 2018.03 v2.11.1 running Go 1.12.4” as current.
Am I correct is understanding this to be a cause of problems?
with my thanks,
Dominic.
Yes, same old problem. I updated the solution stack again, please wait for CD to pass; ~10 minutes.
will this be to the latest version of:
Also been struggling today.
Yes it is
Hi johan, The same old problem, as per last cases mentioned.
"No Solution Stack named ‘64bit Amazon Linux 2018.03 v2.11.1 running Go 1.12.4’ found. (Service: AWSElasticBeanstalk; Status Code: 400; Error Code: InvalidParameterValue; Request ID: acf8ba73-2d8f-4682-be08-b905e48bee17) "
Would you please have a look.
Cheers
The update is on its way, expect ~10 minutes
Marvelous work Johan, Thank you.
Hi I’m new to TTN and I am getting the same error for my AWS Stack:
No Solution Stack named ‘64bit Amazon Linux 2018.03 v2.10.0 running Go 1.11.5’ found. (Service: AWSElasticBeanstalk; Status Code: 400; Error Code: InvalidParameterValue; Request ID: 88d378e3-b07f-424c-8c13-dc82357d8a15)
Would be very appreciated if someone can aid with this!
I’m getting the same error. So it seems AWS guys are changing the versions of Amazon Linux too often! We need to wait for the johan to help.
I wondered if it would help to choose a different Instance Type, instead of default t2.micro? so this tried t2.small but the error was same.
Tried today and worked. All seems to be fine now.
The issue is fixed and working now. Hopefully a permanent fixed can be find.
Hello Johan,
I am currently using Klarrio/ttn-aws-workshop in order to create a stack for AWS to complete the integration side of my IoT project. I am currently using an AWS account created by my professor for research purposes but am having the same difficulty as other users above when attempting to create my stack with the template created (ttn-cloudformation-template) in Klarrio’s repository.
ERROR: No Solution Stack named ‘64bit Amazon Linux 2018.03 v2.11.1 running Go 1.12.4’ found. (Service: AWSElasticBeanstalk; Status Code: 400; Error Code: InvalidParameterValue; Request ID: caabaff1-32a6-4da1-9a66-2e843cd9f8a5)
After reading multiple forums, I have tried changing the SolutionStackName to the following:
  • 64bit Amazon Linux 2017.09 v2.7.5 running Go 1.9
  • 64bit Amazon Linux 2018.03 v2.10.0 running Go 1.11.5
  • 64bit Amazon Linux 2018.03 v2.11.1 running Go 1.12.4
but have had the same issue leading to ROLLBACK_COMPLETE on the stack.
I have continued to change a few things around when creating new stacks like changing TheThingType from lorawan to ttnLoraWan as stated within Klarrio’s repository but no success. Should I try changing the region, SolutionStackName, InstanceType, and/or another parameter in order to confirm the issue by trial and error or am I missing something else??
Your help is much appreciated!
Also, my ttn application handler is set to ttn-handler-us-west if that helps at all.
Thank you!
Hi i have the same problem
“No Solution Stack named ‘64bit Amazon Linux 2018.03 v2.12.1 running Go 1.12.7’ found. (Service: AWSElasticBeanstalk; Status Code: 400; Error Code: InvalidParameterValue; Request ID: …”
any help?
Hi we also have the same problem.
I hope we can get some help. Thank you in advance.
Thanks for the report.
We will update the integration soon.
Edit: The new version is online. You should be able to deploy it now.
Best
Thanks for the fast solution.
But it appears that it still doesn’t work.
“No Solution Stack named ‘64bit Amazon Linux 2018.03 v2.13 running Go 1.13’ found. (Service: AWSElasticBeanstalk; Status Code: 400; Error Code: InvalidParameterValue; Request ID:”
Sorry to bother you again.
@Norddeutsche_Energie Can you try again ? Hopefully it should be good now.
Hello, Could you please update it once again?
No Solution Stack named ‘64bit Amazon Linux 2018.03 v2.13.0 running Go 1.13’ found. (Service: AWSElasticBeanstalk; Status Code: 400; Error Code: InvalidParameterValue)
@Sly1 :roll_eyes: (don’t know if you’ve seen this Q)
