# Meshed-handler
**URL:** <https://www.thethingsnetwork.org/forum/t/meshed-handler/14652>\
**Category:** TTN Network and Services\
**Created:** [May 30, 2018, 12:22am UTC](https://www.thethingsnetwork.org/forum/t/meshed-handler/14652 "2018-05-30T00:22:19Z")\
**Showing post:** 69
**Author:** ![TonySmith](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/tonysmith/32/46334_2.png) [@TonySmith](https://www.thethingsnetwork.org/forum/u/TonySmith)\
**Post date:** [July 27, 2020, 10:58am UTC](https://www.thethingsnetwork.org/forum/t/meshed-handler/14652/69 "2020-07-27T10:58:00Z")
Hi @Maj
> [@Maj](#):
> AU915 UDP gateways should point to au915.thethings.meshed.com.au
> AS923 UDP gateways should point to as923.thethings.meshed.com.au
> AU915 and AS923 MQTT (and other) gateways should point to thethings.meshed.com.au (or router.au.thethings.network)
Thanks for the concise set of links. BTW, this is the first time I have seen the need for a gateway to point to `au915.thethings.meshed.com.au` , I always thought it was `thethings.meshed.com.au` for Au915. That’s the address published on TTN web site when registering a new gateway.
Couldn’t work out why I had never seen this before and went and searched and from what I can see this is the first time “au915.thethings.meshed.com.au” has been published on this forum.
I’m wondering if some of this can be rationalised and realigned with the TTN naming convention used elsewhere around the globe by editing the DNS records for some of these domains.
Just a thought.
_[View the full topic](https://www.thethingsnetwork.org/forum/t/meshed-handler/14652)._
