# Migration Procedure
**URL:** <https://www.thethingsnetwork.org/forum/t/migration-procedure/44978>\
**Category:** Migrating Devices to V3\
**Created:** [February 28, 2021, 11:09pm UTC](https://www.thethingsnetwork.org/forum/t/migration-procedure/44978 "2021-02-28T23:09:36Z")\
**Showing post:** 10
**Post date:** [March 1, 2021, 3:15pm UTC](https://www.thethingsnetwork.org/forum/t/migration-procedure/44978/10 "2021-03-01T15:15:52Z")
You may find search & browse helps.
And in the this category, same as the link above:
> [@How to Migrate OTAA Devices from V2 to V3](https://www.thethingsnetwork.org/forum/t/how-to-migrate-otaa-devices-from-v2-to-v3/43704):
> I’m writing this post as a quick draft that will be extended and eventually turned into a documentation page. Before you Begin We assume your gateway is still connected to V2. Your device will have to perform a new join. If your device doesn’t perform a join procedure regularly (once a week/month), automatically (after it loses connection) and you can’t trigger a join procedure remotely (by sending a downlink), you may have to physically visit your device to If you have easy access to your …
_[View the full topic](https://www.thethingsnetwork.org/forum/t/migration-procedure/44978)._
