Hello, I am making a node with pro-mini + RF95 that has a BME280 plus a soil moisture sensor, the code compiles me, and I am receiving the data from the BME280 without problem but the data from the soil sensor always reaches me a value fixed, but if I print by serial the variable where I capture the value of the soil moisture sensor if it shows me perfect, the library I use is LMIC
#include <lmic.h>
#include <hal/hal.h>
#include <SPI.h>
#include <LowPower.h>
#include <Wire.h>
#include "adcvcc.h"
#include "BME280I2C.h"
#define debugSerial Serial
#define SHOW_DEBUGINFO
#define debugPrintLn(...) { if (debugSerial) debugSerial.println(__VA_ARGS__); }
#define debugPrint(...) { if (debugSerial) debugSerial.print(__VA_ARGS__); }
#define debugFlush() { if (debugSerial) debugSerial.flush(); }
/ / When enable BROWNOUTDISABLED be sure that you have BOD fused.
// #define BROWNOUTDISABLED
//#define NORMALINTERVAL 900 // 15 minutes (normal)
#define NORMALINTERVAL 32 // 32 second (test highspeed)
// Restrict to channel0 if uncommented; otherwise all channels (allways use SF7)
// #define CHANNEL0
//// Choice on of the LMIC pinnings below.
// Pin mapping CH2I (check out : https://www.thethingsnetwork.org/forum/t/full-arduino-mini-lorawan-
and-1-3ua-sleep-mode/8059 )
#define LMIC_NSS 6
#define LMIC_RXTX LMIC_UNUSED_PIN
#define LMIC_RST 5
#define LMIC_DIO0 2
#define LMIC_DIO1 3
#define LMIC_DIO2 4
.nss = LMIC_NSS,
.rxtx = LMIC_RXTX,
.rst = LMIC_RST,
.dio = {LMIC_DIO0, LMIC_DIO1, LMIC_DIO2},
/ / UPDATE WITH YOURE TTN KEYS AND ADDR
static const PROGMEM u1_t NWKSKEY[16] = { 0x13, 0x93, 0x2E, 0x2E, 0xC9, 0xB4, 0xB3, 0x92,
0x17, 0xD3, 0xE9, 0xB3, 0xD7, 0xCA, 0x51, 0xA4 }; // LoRaWAN NwkSKey, network session key
static const u1_t PROGMEM APPSKEY[16] = { 0x29, 0x4D, 0x8C, 0xCF, 0xBF, 0x6E, 0x73, 0x3D,
0xEF, 0x2B, 0x8C, 0x0E, 0x5E, 0x42, 0x33, 0xCE }; // LoRaWAN AppSKey, application session key
static const u4_t DEVADDR = 0x260C0EED ; // LoRaWAN end-device address (DevAddr)
// DISABLE_JOIN is set in config.h, otherwise the linker will complain).
static osjob_t sendjob;
// Valores de calibración Sensor de suelo fpr
const int AirValue = 50; // necesitas reemplazar este valor
const int WaterValue = 900; // necesitas reemplazar este valor
int intervals = (AirValue - WaterValue)/3;
int soilMoistureValue = 0;
//int BattValue = 0;
// Definición de pines
int SoilOut = A0; // ENTRADA del sensor de humedad del suelo
//int BattOut = A1; // ENTRADA Divisor de voltaje
int SoilVCC = 9; // SALIDA del sensor de humedad del suelo
// global enviromental parameters
static float temp = 0.0;
static float pressure = 0.0;
static float humidity = 0.0;
int interval = NORMALINTERVAL;
byte LMIC_transmitted = 0;
int LMIC_event_Timeout = 0;
// cycle limitations).
// const unsigned TX_INTERVAL = 60;
BME280I2C bme; // Default : forced mode, standby time = 1000 ms
// Oversampling = pressure ×1, temperature ×1, humidity ×1, filter off,
Function: ADC_vect
Purpose : IRQ Handler for ADC
Input : -
Output : -
Comments: used for measuring 8 samples low power mode, ADC is then in
free running mode for 8 samples
ISR(ADC_vect)
/ / Increment ADC counter
_adc_irq_cnt++;
void updateEnvParameters()
delay(1000);
temp = bme.temp(true);
pressure = bme.pres(1); // 1 = hPa (milliBar)
humidity = bme.hum();
void onEvent (ev_t ev)
debugPrint(os_getTime());
debugPrint(": ");
debugPrintLn(ev);
switch(ev)
case EV_SCAN_TIMEOUT:
debugPrintLn(F("EV_SCAN_TIMEOUT"));
break;
case EV_BEACON_FOUND:
debugPrintLn(F("EV_BEACON_FOUND"));
break;
case EV_BEACON_MISSED:
debugPrintLn(F("EV_BEACON_MISSED"));
break;
case EV_BEACON_TRACKED:
debugPrintLn(F("EV_BEACON_TRACKED"));
break;
case EV_JOINING:
debugPrintLn(F("EV_JOINING"));
break;
case EV_JOINED:
debugPrintLn(F("EV_JOINED"));
break;
case EV_RFU1:
debugPrintLn(F("EV_RFU1"));
break;
case EV_JOIN_FAILED:
debugPrintLn(F("EV_JOIN_FAILED"));
break;
case EV_REJOIN_FAILED:
debugPrintLn(F("EV_REJOIN_FAILED"));
break;
case EV_TXCOMPLETE:
debugPrintLn(F("EV_TXC"));
debugPrintLn(F("R ACK")); // Received ack
if (LMIC.dataLen)
debugPrintLn(F("R "));
debugPrintLn(LMIC.dataLen);
debugPrintLn(F(" bytes")); // of payload
// Schedule next transmission
// os_setTimedCallback(&sendjob, os_getTime()+sec2osticks(TX_INTERVAL), do_send);
LMIC_transmitted = 1;
break;
case EV_LOST_TSYNC:
debugPrintLn(F("EV_LOST_TSYNC"));
break;
case EV_RESET:
debugPrintLn(F("EV_RESET"));
break;
case EV_RXCOMPLETE:
// data received in ping slot
debugPrintLn(F("EV_RXCOMPLETE"));
break;
case EV_LINK_DEAD:
debugPrintLn(F("EV_LINK_DEAD"));
break;
case EV_LINK_ALIVE:
debugPrintLn(F("EV_LINK_ALIVE"));
break;
default:
debugPrintLn(F("Unknown event"));
break;
void do_send(osjob_t* j)
if (LMIC.opmode & OP_TXRXPEND)
debugPrintLn(F("OP_TXRXPEND")); //P_TXRXPEND, not sending
else
// Here the sensor information should be retrieved
// Pressure: 300...1100 hPa
// Temperature: -40…85°C
updateEnvParameters();
int batt = (int)(readVcc() / 100); // readVCC returns mVolt need just 100mVolt steps
byte batvalue = (byte)batt; // no problem putting it into a int.
digitalWrite(SoilVCC, HIGH); // activa el pin digital 13
delay(1000); // espera un segundo
soilMoistureValue = averageAnalogRead(SoilOut); // coloque el inserto del sensor en el suelo
digitalWrite(SoilVCC, LOW);
#ifdef SHOW_DEBUGINFO
debugPrint(F("T="));
debugPrintLn(temp);
debugPrint(F("P="));
debugPrintLn(pressure);
debugPrint(F("H="));
debugPrintLn(humidity);
debugPrint(F("B="));
debugPrintLn(batt);
debugPrint(F("BV="));
debugPrintLn(batvalue);
debugPrint(F("S="));
debugPrintLn(soilMoistureValue);
#endif
int t = (int)((temp + 40.0) * 10.0);
// t = t + 40; => t [-40..+85] => [0..125] => t = t * 10; => t [0..125] => [0..1250]
int p = (int)(pressure); // p [300..1100]
int h = (int)(humidity);
int s = (int) (soilMoistureValue);
unsigned char mydata[8];
mydata[0] = batvalue;
mydata[1] = h & 0xFF;
mydata[2] = t >> 8;
mydata[3] = t & 0xFF;
mydata[4] = p >> 8;
mydata[5] = p & 0xFF;
mydata[6] = s >> 8;
mydata[7] = s & 0xFF;
LMIC_setTxData2(1, mydata, sizeof(mydata), 0);
debugPrintLn(F("PQ")); //Packet queued
// Toma un promedio de lecturas en un pin dado
// Devuelve el promedio
int averageAnalogRead(int pinToRead)
byte numberOfReadings = 8;
unsigned int runningValue = 0;
for(int x = 0 ; x < numberOfReadings ; x++)
runningValue += analogRead(pinToRead);
runningValue /= numberOfReadings;
return(runningValue);
bool bootFromBrownOut = false;
// shows the bootstatus on serial output and set bootFromBrownout flag.
void showBootStatus(uint8_t _mcusr)
debugPrint(F("mcusr = "));
debugPrint(_mcusr, HEX);
debugPrint(F(" > "));
if (_mcusr & (1<<WDRF))
debugPrint(F(" WDR"));
_mcusr &= ~(1<<WDRF);
if (_mcusr & (1<<BORF))
debugPrint(F(" BOR"));
_mcusr &= ~(1<<BORF);
bootFromBrownOut = true;
if (_mcusr & (1<<EXTRF))
debugPrint(F(" EXTF"));
_mcusr &= ~(1<<EXTRF);
if (_mcusr & (1<<PORF))
debugPrint(F(" POR"));
_mcusr &= ~(1<<PORF);
if (_mcusr != 0x00)
// It should never enter here
debugPrint(F(" ??"));
debugPrintLn("");
void setup()
uint8_t mcusr = MCUSR;
MCUSR = 0;
pinMode(SoilOut, INPUT);
//pinMode(BattOut, INPUT);
pinMode(SoilVCC, OUTPUT);
Serial.begin(115200);
debugPrintLn(F("Boot"));
showBootStatus(mcusr);
#if BROWNOUTDISABLED
// warning when using code below, disable brownout detection.
// For Arduino Pro Mini 8Mhz 3.3V
// MiniCore : ATMega328
// Clock : 8Mhz external
// Compiler LTO : Enabled
// Variant : 328P/328PA
// BOD : Disabled
int batt = readVcc(); // do initial read, readVCC returns mVolt
debugPrintLn(batt);
while (batt < 1800)
debugPrintLn(F("low power !"));
LowPower.powerDown(SLEEP_8S, ADC_OFF, BOD_ON);
batt = readVcc(); // readVCC returns mVolt
// until here
#endif
while (1)
if (bme.begin())
break;
debugPrintLn(F("No valid bme280 sensor!"));
debugFlush();
// LMIC init
os_init();
LMIC_reset();
#ifdef PROGMEM
LMIC_setSession (0x1, DEVADDR, nwkskey, appskey);
#else
LMIC_setSession (0x1, DEVADDR, NWKSKEY, APPSKEY);
#endif
#if defined(CFG_eu868)
// Set up the channels used by the Things Network, which corresponds
// to the defaults of most gateways. Without this, only three base
// channels from the LoRaWAN specification are used, which certainly
// works, so it is good for debugging, but can overload those
// frequencies, so be sure to configure the full frequency range of
// your network here (unless your network autoconfigures them).
// Setting up channels should happen after LMIC_setSession, as that
// configures the minimal channel set.
// NA-US channels 0-71 are configured automatically
LMIC_setupChannel(0, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); //
g-band
LMIC_setupChannel(1, 868300000, DR_RANGE_MAP(DR_SF12, DR_SF7B), BAND_CENTI); //
g-band
LMIC_setupChannel(2, 868500000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); //
g-band
LMIC_setupChannel(3, 867100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); //
g-band
LMIC_setupChannel(4, 867300000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); //
g-band
LMIC_setupChannel(5, 867500000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); //
g-band
LMIC_setupChannel(6, 867700000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); //
g-band
LMIC_setupChannel(7, 867900000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); //
g-band
LMIC_setupChannel(8, 868800000, DR_RANGE_MAP(DR_FSK, DR_FSK), BAND_MILLI); //
g2-band
// For single channel gateways: Restrict to channel 0 when defined above
#ifdef CHANNEL0
LMIC_disableChannel(1);
LMIC_disableChannel(2);
LMIC_disableChannel(3);
LMIC_disableChannel(4);
LMIC_disableChannel(5);
LMIC_disableChannel(6);
LMIC_disableChannel(7);
LMIC_disableChannel(8);
#endif
// TTN defines an additional channel at 869.525Mhz using SF9 for class B
// devices' ping slots. LMIC does not have an easy way to define set this
// frequency and support for class B is spotty and untested, so this
// frequency is not configured here.
#elif defined(CFG_us915)
// but only one group of 8 should (a subband) should be active
// TTN recommends the second sub band, 1 in a zero based count.
// https://github.com/TheThingsNetwork/gateway-conf/blob/master/US-global_conf.json
LMIC_selectSubBand(1);
#endif
LMIC_setLinkCheckMode(0);
LMIC.dn2Dr = DR_SF9;
// Set data rate and transmit power for uplink (note: txpow seems to be ignored by the library)
LMIC_setDrTxpow(DR_SF7,14);
debugPrintLn(F("S")); // Setup complete!"
debugFlush();
void loop()
if (!bootFromBrownOut)
// Start job
do_send(&sendjob);
// Wait for response of the queued message (check if message is send correctly)
os_runloop_once();
// Continue until message is transmitted correctly
debugPrintLn(F("W")); // aiting for transmittion
LMIC_event_Timeout = 60*100; // 60 * 100 times 10mSec = 60 seconds
while(LMIC_transmitted != 1)
os_runloop_once();
// Add timeout counter when nothing happens:
delay(10);
if (LMIC_event_Timeout-- == 0)
// Timeout when there's no "EV_TXCOMPLETE" event after 60 seconds
debugPrintLn(F("ETO, msg not tx"));
break;
else
debugPrintLn("X");
debugPrintLn(F("G"));
debugFlush();
for (int i = 0; i < interval; i++)
i +=8 ; // no normal 1 second run but 8 second loops m.
// Enter power down state for 8 s with ADC and BOD module enabled
debugPrintLn("-");
