# Moving a device from Loriot to TTN
**URL:** <https://www.thethingsnetwork.org/forum/t/moving-a-device-from-loriot-to-ttn/17295>\
**Created:** [August 29, 2018, 2:43pm UTC](https://www.thethingsnetwork.org/forum/t/moving-a-device-from-loriot-to-ttn/17295 "2018-08-29T14:43:45Z")\
**Showing post:** 6
**Post date:** [September 26, 2018, 3:42pm UTC](https://www.thethingsnetwork.org/forum/t/moving-a-device-from-loriot-to-ttn/17295/6 "2018-09-26T15:42:42Z")
> [@nestorayuso](#):
> use ttnctl to change device’s DevAddr with the value provided from loriot
Did you (recently) try that? Even if it works today, I’m quite sure it’s not a future proof way to do this. @htdvisser has been very clear about this:
> [@Can I register an ABP device that has fixed DevAddr, NwkSKey and AppSKey?](https://www.thethingsnetwork.org/forum/t/can-i-register-an-abp-device-that-has-fixed-devaddr-nwkskey-and-appskey/3831/17):
> @htdvisser wrote in Slack […]:
> > But uplink for anything else than `00` / `01` / `26` / `27` will just be dropped before it’s even considered by the backend
Also, no downlink also implies no ADR.
And this is bogus:
> [@mfalkvidd](#):
> The vendor also claims the following:
> - the dev addr is optional when using ABP
And, yes:
> [@mfalkvidd](#):
> Could it be that Blink Services and Loriot route all messages, regardless of dev addr prefix
Of course, but they should not?
> [@mfalkvidd](#):
> We have now gotten information from the vendor that the devices use ABP.
Bummer. For ABP, TTN’s answer is clear; see [Can I register an ABP device that has fixed DevAddr, NwkSKey and AppSKey?](https://www.thethingsnetwork.org/forum/t/can-i-register-an-abp-device-that-has-fixed-devaddr-nwkskey-and-appskey/3831) Also beware that the [backend network stack version V3](https://www.thethingsnetwork.org/forum/t/the-things-network-stack-v3-webinar-by-johan-stokking/12031) is due, so don’t rely on hacks that work in the current V2…
_[View the full topic](https://www.thethingsnetwork.org/forum/t/moving-a-device-from-loriot-to-ttn/17295)._
