Hi @kersing
I have been working with the packet forwarded to TTN for while as you know and have recently changed the config on the conduit to act as a local gateway to a private network while providing OTAA to nodes from the gateway. the problem is when i used the same code on TTN i use to receive all my payload packets when expected EU868 band. now on the coduit i recieve a packet every 30 minutes if im lucky. I have looked into the issues with the Lmic library but that never effected me while using TTN as it did others. can you maybe explain or take a guess what you do with the packet forwarding script on the conduit that would otherwise cause this issues ? below is my server config file.
7:23:33:728|INFO| LoRa Network Server started, version 1.0.26
7:23:33:737|INFO| Loaded default global_conf.json from /var/config/lora/
7:23:33:751|TRACE| Generating Network Id...
7:23:33:752|TRACE| Generating Network Key...
7:23:33:753|WARNING| Setting for beacon interval not found. Beacon is disabled.
7:23:33:754|INFO| LoRa Card AP 1: MTAC-LORA-868 MTAC-LORA-1.0
7:23:33:754|INFO| LoRa Card AP 2:
7:23:33:757|INFO| Network Server Config ---------------------
"addressRange" : {
"end" : "FF:FF:FF:FE",
"start" : "00:00:00:01"
"db" : "/var/config/lora/lora-network-server.db",
"log" : {
"console" : false,
"level" : 100,
"path" : "/var/log/lora-network-server.log",
"syslog" : false
"lora" : {
"ADRStep" : 30,
"beaconDelay" : 0,
"beaconInterval" : 0,
"beaconPower" : 27,
"channelPlan" : "EU868",
"dutyCyclePeriod" : 60,
"eui_1" : "00:80:00:00:00:00:9A:B0",
"frequencyAS" : 922600000,
"frequencyBand" : "EU868",
"frequencyEU" : 867500000,
"frequencyKR" : 922900000,
"frequencySubBand" : 7,
"joinByteOrder" : "LSB",
"joinDelay" : 5,
"maxDatarate" : 5,
"maxDatarateEU" : 5,
"maxDatarateUS" : 4,
"maxTxPower" : 14,
"minDatarate" : 0,
"minDatarateEU" : 0,
"minDatarateUS" : 0,
"netID" : "010203",
"rx1DatarateOffset" : 0,
"rx1Delay" : 1,
"rx2Datarate" : 7,
"rx2Frequency" : 869525000
"mqtt" : {
"enabled" : true
