The forum got a pretty nice upgrade today, you can now use your TTN account to log in and register. The username remains in the scope of the forum, you can have a different one for this platform.
We sync the existing user account on the forum to your TTN account with the email address.
So:
1. If you do not yet have an TTN account. Create one with the same email address as the one you use for this forum.
2. If you do have a TTN account. Check if you use the same email address. If not, change the one in your TTN account to the one on this forum. Or contact us so we can fix it on the forum. See email below.
Last but not least, the forum uses HTTPS encryption and is under www.thethingsnetwork.org/forum … the old links will be redirected to new one.
Beware of references to the deprecated REST API (sometimes referred to as “Croft/Jolie”, using URLs starting with thethingsnetwork.org/api); see Connect an Application to use MQTT instead.
You cannot log into the forum when already logged into the dashboard with another account. You need to log into the forum, then log into the dashboard again. Logging into the forum while still logged into the dashboard wants you to login or register using those details. Only way to get out of that was to logout of dashboard first.
