# No RX TTGO-BEAM with TTN Mapper
**URL:** <https://www.thethingsnetwork.org/forum/t/no-rx-ttgo-beam-with-ttn-mapper/20037>\
**Category:** TTKG - The Things Kickstarter Gateway\
**Created:** [November 22, 2018, 10:26pm UTC](https://www.thethingsnetwork.org/forum/t/no-rx-ttgo-beam-with-ttn-mapper/20037 "2018-11-22T22:26:10Z")\
**Showing post:** 2
**Post date:** [November 23, 2018, 7:13am UTC](https://www.thethingsnetwork.org/forum/t/no-rx-ttgo-beam-with-ttn-mapper/20037/2 "2018-11-23T07:13:02Z")
Why are you expecting any RX at all?
You’ll only get RX for _confirmed_ uplinks, if your application explicitly schedules a downlink, and for network commands like those for ADR. For mapping, you should not use confirmed uplinks, and for other usages downlinks (including confirmed uplinks) are [limited to only 10 a day](https://www.thethingsnetwork.org/forum/t/limitations-data-rate-packet-size-30-seconds-uplink-and-10-messages-downlink-per-day-fair-access-policy/1300).
Please see [https://www.thethingsnetwork.org/docs/lorawan/](https://www.thethingsnetwork.org/docs/lorawan/)
> [@beekeepernetwork](#):
> ```cpp
> // ========= CODE changed to see if there RX action????
> //if (LMIC.dataLen) {
> sprintf(s, "Received %i bytes of payload", LMIC.dataLen);
> Serial.println(s);
> sprintf(s, "RSSI %d SNR %.1d", LMIC.rssi, LMIC.snr);
> Serial.println(s);
> //} //// uncomment to test RX data
The original code already shows you the RX _if there is any_. If you want to change the logging, I’d simply only move `sprintf(s, "Received %i bytes of payload", LMIC.dataLen);` above the `if (LMIC.dataLen)`. But I’d leave the `if` in place; you’re now logging RSSI and SNR values that are really not true.
> sketch = Lora-TTNMapper-T-Beam-master.zip
Well, the internet is big, just a file name won’t help most of us 🙂
_[View the full topic](https://www.thethingsnetwork.org/forum/t/no-rx-ttgo-beam-with-ttn-mapper/20037)._
