# No RX TTGO-BEAM with TTN Mapper
**URL:** <https://www.thethingsnetwork.org/forum/t/no-rx-ttgo-beam-with-ttn-mapper/20037>\
**Category:** TTKG - The Things Kickstarter Gateway\
**Created:** [November 22, 2018, 10:26pm UTC](https://www.thethingsnetwork.org/forum/t/no-rx-ttgo-beam-with-ttn-mapper/20037 "2018-11-22T22:26:10Z")\
**Showing post:** 6
**Post date:** [November 24, 2018, 3:36pm UTC](https://www.thethingsnetwork.org/forum/t/no-rx-ttgo-beam-with-ttn-mapper/20037/6 "2018-11-24T15:36:39Z")
> [@beekeepernetwork](#):
> i noticed the frame counter is counting
Where do you see that? In the device’s page in TTN Console? (If yes, then the secret keys are correct, and indeed at least one gateway has received the device’s data, and TTN has determined which application and device the incoming data belongs to.)
> So frames are coming in, but are not seen in the DATA.
You mean the device’s Data page in TTN Console? Beware that you will only see the data that was received since you have that Data page open. To (partially) see recent older data as well you can add the Storage Integration to the application; see [Why application data is shown as historical? - #2 by arjanvanb](https://www.thethingsnetwork.org/forum/t/why-application-data-is-shown-as-historical/8793/2)
> Could this be that the format does not fit?
Are you saying you’re using some Payload Format function in TTN Console? If not, then TTN should simply show the hexadecimal representation of the payload.
_[View the full topic](https://www.thethingsnetwork.org/forum/t/no-rx-ttgo-beam-with-ttn-mapper/20037)._
