# Node with ESP8266 and RFM95W
**URL:** <https://www.thethingsnetwork.org/forum/t/node-with-esp8266-and-rfm95w/1002>\
**Category:** Hardware\
**Created:** [January 9, 2016, 10:40pm UTC](https://www.thethingsnetwork.org/forum/t/node-with-esp8266-and-rfm95w/1002 "2016-01-09T22:40:06Z")\
**Showing post:** 45
**Author:** ![greger-isaksson](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/greger-isaksson/32/35697_2.png) [@greger-isaksson](https://www.thethingsnetwork.org/forum/u/greger-isaksson)\
**Post date:** [March 20, 2016, 8:55am UTC](https://www.thethingsnetwork.org/forum/t/node-with-esp8266-and-rfm95w/1002/45 "2016-03-20T08:55:00Z")
I recognized that the TTN gateway will not be available soon and that Microchip RN2483 is out of stock. Just too have something working in short time I found out that a very cheap and simple experimental setup with an single\_channel\_gateway, [https://github.com/tftelkamp/single\_chan\_pkt\_fwd](https://github.com/tftelkamp/single_chan_pkt_fwd)
built on RPI and SX1272, and a node built on ESP-12 (ESP8266) and SX1272 is possible.
matthijs presented an updated version of arduino-lmic library 29 days ago. [https://github.com/matthijskooijman/arduino-lmic](https://github.com/matthijskooijman/arduino-lmic).
The code will compile for ESP8266 in Arduino IDE without problem and with some small modification as below it is possible to force transmission to only one channel, the same channel as the single-channel-gateway is listening on. The pin mapping can also leave dio3 unused as I will not use the FSK channel at all, this means that I can use the serial port for input of new data for transmission.
// Pin mapping
const lmic\_pinmap lmic\_pins = {
.nss = 15,
.rxtx = LMIC\_UNUSED\_PIN,
.rst = 16,
.dio = {5, 4, LMIC\_UNUSED\_PIN},
SX1272 dio2 → GND // Only used for PSK, not used in my case
//Changes in Arduino code, setup
// configures the minimal channel set.
LMIC_setupChannel(0, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(1, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(2, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(3, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(4, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(5, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(6, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(7, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
LMIC_setupChannel(8, 868100000, DR_RANGE_MAP(DR_SF12, DR_SF7), BAND_CENTI); // g-band
// LMIC\_setupChannel(1, 868300000, DR\_RANGE\_MAP(DR\_SF12, DR\_SF7B), BAND\_CENTI); // g-band
// LMIC\_setupChannel(2, 868500000, DR\_RANGE\_MAP(DR\_SF12, DR\_SF7), BAND\_CENTI); // g-band
// LMIC\_setupChannel(3, 867100000, DR\_RANGE\_MAP(DR\_SF12, DR\_SF7), BAND\_CENTI); // g-band
// LMIC\_setupChannel(4, 867300000, DR\_RANGE\_MAP(DR\_SF12, DR\_SF7), BAND\_CENTI); // g-band
// LMIC\_setupChannel(5, 867500000, DR\_RANGE\_MAP(DR\_SF12, DR\_SF7), BAND\_CENTI); // g-band
// LMIC\_setupChannel(6, 867700000, DR\_RANGE\_MAP(DR\_SF12, DR\_SF7), BAND\_CENTI); // g-band
// LMIC\_setupChannel(7, 867900000, DR\_RANGE\_MAP(DR\_SF12, DR\_SF7), BAND\_CENTI); // g-band
// LMIC\_setupChannel(8, 868800000, DR\_RANGE\_MAP(DR\_FSK, DR\_FSK), BAND\_MILLI); // g2-band
_[View the full topic](https://www.thethingsnetwork.org/forum/t/node-with-esp8266-and-rfm95w/1002)._
