[PCB] Pro mini / RFM95W / 18650 solar chargeable
Yes, I had watched the AVR version. The Lora version is great !! :slight_smile:
Hi!
Do yo plan to release/share the PCB design for your board?
Thanks!
I received it today. Looks very nice, in particular that you added the ground plane below the rfm. I’ll order some components and then I’ll post an update.
Wijnand_board
received today a well documented gift. Thanks @Wijnand
now it’s soldering time :sunglasses:
Wijnand_board_running
:smiley::smiley::smiley:
soldered, up and running
and already some ideas :wink:
Hi Wijnand,
Do you still have a pcb’s available? If so, I would like to receive one
Kind regards,
I am also very interrested in such a board. Would you publish the schematics here or somwhere else?
Thomas
Hello.
I recieved fine PCB from @Wijnand.
A big THANK YOU!
Pictures follows.
Greets.
Hi @All
So i know @Wijnand would share his PCBs. He let us know: What's your experience with pcbs.io?
Something goes wrong with his account. I don`t know how to help. New owner of pcbs.io is https://www.makerbright.com/ ?
Is that the solution to get in contact to solve the problem?
Greets
I uploaded the design to pcbs.io again and that works.
Hey @Wijnand cool! :slight_smile:
Are you sharing? And show a link to the PCB?
Regards
For better use of the battery it could be used the MCP1700-300 (3 V output) or MCP1700-280 (2.8V output) to take into account the dropout voltage.
MCP1700 typical dropout voltage is 178 mV and maximum 350 mV at 25°C and load 250 mA.
Hello Mario
Great work!
One thing: I always try to avoid the linked battery holder in your blog, this spring version is very bad, maybe this is not a real issue at those low power applications, but the contact between the springs and the battery is very poor. I therefore always use some massive battery holders, like this one: https://www.aliexpress.com/item//32691749341.html
Where can we order the boards?
If you could share the files for the 3D case would be great! I could also print some if someone from Switzerland is interested in the case and doesn’t have a printer.
Thank you!
Hello my friend!
Theoretically, I can share the plans, but I’m currently working on version 2. This will be completely open hardware and so I can upload them on various platforms.
I hope you have a little patience;)
Is there anyone with experience with the CC1310? My new design (a VT-s02c module from Vincent Tang/China equipped with a CC1310 from Texas Instruments) is the next step to go to an IoT node supporting services for 10 years with a CR2032 coin cell battery (see for the concept: http://www.ti.com/tool/TIDA-00484). You can find the PCB at https://PCBs.io/share/rG9GP. Not tested yet!!!
Do those modules support LoRa modulation? The only references I found mention it supporting a modulation similar to LoRa.
First (after I recieved the PCB’s) I am going to test the power concept of TI. Next step to test the HF. I just read “no LoRa support”, see: http://e2e.ti.com/support/wireless_connectivity/proprietary_sub_1_ghz_simpliciti/f/156/t/611585
Not specifically, but it looks like its a FSK type device which needs signal levels around 5dB to 10dB above noise level to operate, wheras LoRa devices can operate at up to 20dB below noise level, a significant link margin improvement.
The LoRa devices go down to circa 0.2uA in sleep mode so why would you want to use something else ?
If you want to order my design from pcbs.io, maybe you have to wait a few days because there will be an update soon. Improved the antenna connection (@marioz) and ADC6 and ADC7 (analog exclusivily) are not connected to JP3 anymore but PB0 and PB1 (possibility for soft serial).
hi Wijnand
when do you update? There is still the “old” version on PCBs.io
thanks
