PPPD could not be initiated Kerlink_V3.1
(Akishore Planon) #1
Facing the below error when we started the GPRS module manually with the file that is in /etc/init. Need Help.
Kerlink version :
KERNEL_VER=3.10.104-3.10.104-klk6
PIC_VER=8.3
BOOTSTRAP_VER=""
UBOOT_VER="U-Boot 2009.03-2009.03-klk1 (Dec 27 2016 - 16:23:47)"
SCRIPT_VER=v1.0
INITRAMFS_VER=v1.1
FILESYSTEM_VER=2016.05v1.5
KNETD_VER="wirma2_v4.09 WAN_3.16 (Dec 23 2016-14:33:40)"
PROD_FW=wirmaV2_wirnet_v3.1
LORABOARD_MANUFACTURER=00
LORABOARD_TYPE="868-27dBm"
LORABOARD_HWVERSION=05
LORABOARD_SERIALNO=00165E
These are the logs that come from /var/log/messages :
Oct 11 07:01:49 Wirgrid daemon.notice pppd[11873]: pppd 2.4.7 started by root, uid 0
Oct 11 07:01:50 Wirgrid local2.info chat[11880]: send (\dAT+CGDCONT=1,“IP”,“portalmmm.nl”^M)
Oct 11 07:01:52 Wirgrid local2.info chat[11880]: expect (OK)
Oct 11 07:01:52 Wirgrid local2.info chat[11880]: AT+CGDCONT=1,“IP”,“portalmmm.nl”^M^M
Oct 11 07:01:52 Wirgrid local2.info chat[11880]: ERROR^M
Oct 11 07:01:55 Wirgrid local2.info chat[11880]: alarm
Oct 11 07:01:55 Wirgrid local2.info chat[11880]: Failed
Oct 11 07:01:55 Wirgrid daemon.debug pppd[11873]: Script /usr/sbin/chat -t 3 -v -f /tmp/chatstart finished (pid 11879), status = 0x3
Oct 11 07:01:55 Wirgrid daemon.err pppd[11873]: Connect script failed
Oct 11 07:01:56 Wirgrid daemon.info pppd[11873]: Exit.
We started the GPRS module manually with the file that is in /etc/init.d .
The command to start it was ./gprs start.
That command returned :
RES_KO
(Akishore Planon) #2
We found the best solution for this issue. If anyone runs into the same issue. Please reply below :slight_smile:
(Wodec) #3
same issue here:
[root@Wirnet~]# /etc/init.d/gprs status
pppd is stopped
[root@Wirnet~]# /etc/init.d/gprs start
RES_KO
Wirgrid daemon.notice pppd[12361]: pppd 2.4.7 started by root, uid 0
Wirgrid local2.info chat[12368]: send (\dAT+CGDCONT=1,“IP”,“internet.proximus.be”^M)
Wirgrid local2.info chat[12368]: expect (OK)
Wirgrid local2.info chat[12368]: AT+CGDCONT=1,“IP”,“internet.proximus.be”^M^M
Wirgrid local2.info chat[12368]: ERROR^M
Wirgrid authpriv.info dropbear[12378]: Child connection from 123.183.209.139:21309
Wirgrid local2.info chat[12368]: alarm
Wirgrid local2.info chat[12368]: Failed
Wirgrid daemon.debug pppd[12361]: Script /usr/sbin/chat -t 3 -v -f /tmp/chatstart finished (pid 12367), status = 0x3
Wirgrid daemon.err pppd[12361]: Connect script failed
Wirgrid daemon.info pppd[12361]: Exit.
Wirgrid authpriv.info dropbear[12345]: Exit before auth: Exited normally
Could you share your solution ?
(Akishore Planon) #4
The issue was the SIM card is inserted Reverse. Just remove the SIM card and insert it correctly and it works :slight_smile:
(Wodec) #5
small update, issue solved by deleting the SIM GPRS PIN in the gateway config
