I am a beginner doing projects with TTN Currently I am working with Microchip SAMR34.I was trying to do a project where it reads the entered number and dsiplays it, The enetred number can be seen using an Emulator. I have used TeraTerm for this purpose.
The serial Data handler given in the example Project reads only one character, I have modified the code in such a way it reads more than one character at a time. The value received is stored int to a buffer SerialBuffer, But once number is entered for join request, its stops the application process and doesnot moves further.
The code given below is from the example project:
static char SerialBuffer;
void serial_data_handler(void)
int rxChar;
char serialData;
/* verify if there was any character received*/
if (startReceiving == true) {
if((-1) != (rxChar = sio2host_getchar_nowait())) {
serialData = (char)rxChar;
if((serialData != ‘\r’) && (serialData != ‘\n’) && (serialData != ‘\b’)) {
startReceiving = false;
serialBuffer = rxChar;
appPostTask(PROCESS_TASK_HANDLER);
printf("\r\n");
what i have tried: But it is not working !
// uint8_t rxChar;
char serialData;
char arr[10];
char recv;
int i = 0;
int value;
recv = 0x00;
while(('\n' != recv)&&('\r' != recv) && ('\b' != recv)) {
recv = sio2host_getchar();
arr[i] = recv;
i++;
//startReceiving = false;
value =(int)atoi(arr);
serialBuffer = value;
if anyone has any idea, please share . It would be a great help!
APPS_ENDDEVICE_DEMO1
ATSAMR34 Mote Application
I have added twoextra task handlers within the projects to display and process the transmoit data.
static SYSTEM_TaskStatus_t displayTask(void)
switch(appTaskState)
case RESTORE_BAND_STATE:
displayRunRestoreBand();
break;
case DEMO_CERT_APP_STATE:
displayRunDemoCertApp();
break;
case DEMO_APP_STATE:
displayRunDemoApp();
break;
case JOIN_SEND_STATE:
displayJoinAndSend();
break;
case TRANSMIT_DATA_STATE:
displaytransmitData();
break;
default:
printf(“Error STATE Entered\r\n”);
break;
return SYSTEM_TASK_SUCCESS;
static SYSTEM_TaskStatus_t processTask(void)
processRunRestoreBand();
break;
processRunDemoCertApp();
break;
processRunDemoApp();
break;
processJoinAndSend();
break;
processtransmitData();
break;
default:
break;
static void displaytransmitData(void)
printf("\r\nEnter the number to be transmitted: ");
set_LED_data(LED_AMBER, &off);
set_LED_data(LED_GREEN, &off);
startReceiving = true;
//appTaskState = TRANSMIT_DATA_STATE;
//appPostTask(PROCESS_TASK_HANDLER);
static void processtransmitData(void)
TransmitData();
static void TransmitData(void)
printf(" \r\nThe entered number is: %c", serialBuffer);
appTaskState = JOIN_SEND_STATE;
appPostTask(DISPLAY_TASK_HANDLER);
