# Problems connecting RAK2287 to TTN as a gateway
**URL:** <https://www.thethingsnetwork.org/forum/t/problems-connecting-rak2287-to-ttn-as-a-gateway/39613>\
**Category:** RAK Gateways\
**Created:** [September 2, 2020, 2:46pm UTC](https://www.thethingsnetwork.org/forum/t/problems-connecting-rak2287-to-ttn-as-a-gateway/39613 "2020-09-02T14:46:10Z")\
**Showing post:** 2
**Author:** ![Jeff-UK](https://www.thethingsnetwork.org/forum/user_avatar/www.thethingsnetwork.org/jeff-uk/32/35697_2.png) [@Jeff-UK](https://www.thethingsnetwork.org/forum/u/Jeff-UK)\
**Post date:** [September 2, 2020, 3:48pm UTC](https://www.thethingsnetwork.org/forum/t/problems-connecting-rak2287-to-ttn-as-a-gateway/39613/2 "2020-09-02T15:48:51Z")
There is an issue where the Console doesnt always show gw’s as connected - do you have a node (known good!) sending data that you can see in Application?
> [@TTN V2 Console not working properly all the time](https://www.thethingsnetwork.org/forum/t/ttn-console-not-working-properly-all-the-time-console-gateway-not-connected-no-traffic-application-no-data/37915/1):
> The TTN Console is not working properly all the time The following issues can manifest: Gateway is shown in TTN Console as ‘not connected’ or e.g. ‘last seen 1 days ago’ while the gateway is actually connected. The disadvantage of this is that the TTN Console gateway status is unreliable and that the gateway Traffic cannot be monitored in the console. TTN Console shows no Data for an application and/or its devices, while the application actually does receive data from devices. The disadv…
Also double check the MAC Addr used to register as GW (on a Pi use the Enet Mc vs WiFi MAC even if connecting on Wifi only - unless you are usinga Pi0W ofcourse.
Assume you checked legacy forwarder if using UDP when registering?
> [@aal7](#):
> DCA6
Check that is correct… and typed correctly. Most PI’s I’ve seen start B82 - though that may have changed with the Pi4 - (dont use one for a gateway yet) so am suspicious there…
Also try monitoring with ttnctl & command line… vs using console (Search forum & docs & GIYF.)
_[View the full topic](https://www.thethingsnetwork.org/forum/t/problems-connecting-rak2287-to-ttn-as-a-gateway/39613)._
