Proposal for EU-433 frequency plan
(Sowislo) #1
I work with a RAK831 - 433MHz. all works well, but in downlink I get a confirm packet with a frequency from the 868MHz range because I can only setup a EU868 plan for gateway configuration.
Here is my proposal for an 433MHz plan, as a base (from RAK support) I give you a global_conf.json with 8 channels:
 "SX1301_conf": {
        "lorawan_public": true,
        "clksrc": 1, /* radio_1 provides clock to concentrator */
        "antenna_gain": 0, /* antenna gain, in dBi */
        "radio_0": {
            "enable": true,
            "type": "SX1255",
            "freq": 434375000,
            "rssi_offset": -166.0,
            "tx_enable": true,
            "tx_freq_min": 433050000,
            "tx_freq_max": 434900000
        "radio_1": {
            "enable": true,
            "type": "SX1255",
            "freq": 433575000,
            "tx_enable": false
        "chan_multiSF_0": {
            /* Lora MAC channel, 125kHz, all SF, 433.175 MHz */
            "enable": true,
            "radio": 1,
            "if": -400000
        "chan_multiSF_1": {
            /* Lora MAC channel, 125kHz, all SF, 433.375 MHz */
            "enable": true,
            "radio": 1,
            "if": -200000
        "chan_multiSF_2": {
            /* Lora MAC channel, 125kHz, all SF, 433.575 MHz */
            "enable": true,
            "radio": 1,
            "if": 0
        "chan_multiSF_3": {
            /* Lora MAC channel, 125kHz, all SF, 433.975 MHz */
            "enable": true,
            "radio": 0,
            "if": -400000
        "chan_multiSF_4": {
            /* Lora MAC channel, 125kHz, all SF, 434.175 MHz */
            "enable": true,
            "radio": 0,
            "if": -200000
        "chan_multiSF_5": {
            /* Lora MAC channel, 125kHz, all SF, 434.375 MHz */
            "enable": true,
            "radio": 0,
            "if": 0
        "chan_multiSF_6": {
            /* Lora MAC channel, 125kHz, all SF, 434.575 MHz */
            "enable": true,
            "radio": 0,
            "if": 200000
        "chan_multiSF_7": {
            /* Lora MAC channel, 125kHz, all SF, 434.775 MHz */
            "enable": true,
            "radio": 0,
            "if": 400000
        "chan_Lora_std": {
            /* Lora MAC channel, 250kHz, SF7, 434.175 MHz */
            "enable": true,
            "radio": 1,
            "if": -200000,
            "bandwidth": 250000,
            "spread_factor": 7
        "chan_FSK": {
            /* FSK 50kbps channel, 434.675 MHz */
            "enable": true,
            "radio": 1,
            "if": 300000,
            "bandwidth": 125000,
            "datarate": 50000
        "tx_lut_0": {
            /* TX gain table, index 0 */
            "pa_gain": 0,
            "mix_gain": 8,
            "rf_power": -6,
            "dig_gain": 0
        "tx_lut_1": {
            /* TX gain table, index 1 */
            "pa_gain": 0,
            "mix_gain": 10,
            "rf_power": -3,
            "dig_gain": 0
        "tx_lut_2": {
            /* TX gain table, index 2 */
            "pa_gain": 0,
            "mix_gain": 12,
            "rf_power": 0,
            "dig_gain": 0
        "tx_lut_3": {
            /* TX gain table, index 3 */
            "pa_gain": 1,
            "mix_gain": 8,
            "rf_power": 3,
            "dig_gain": 0
        "tx_lut_4": {
            /* TX gain table, index 4 */
            "pa_gain": 1,
            "mix_gain": 10,
            "rf_power": 6,
            "dig_gain": 0
        "tx_lut_5": {
            /* TX gain table, index 5 */
            "pa_gain": 1,
            "mix_gain": 12,
            "rf_power": 10,
            "dig_gain": 0
        "tx_lut_6": {
            /* TX gain table, index 6 */
            "pa_gain": 1,
            "mix_gain": 13,
            "rf_power": 11,
            "dig_gain": 0
        "tx_lut_7": {
            /* TX gain table, index 7 */
            "pa_gain": 2,
            "mix_gain": 9,
            "rf_power": 12,
            "dig_gain": 0
        "tx_lut_8": {
            /* TX gain table, index 8 */
            "pa_gain": 1,
            "mix_gain": 15,
            "rf_power": 13,
            "dig_gain": 0
        "tx_lut_9": {
            /* TX gain table, index 9 */
            "pa_gain": 2,
            "mix_gain": 10,
            "rf_power": 14,
            "dig_gain": 0
        "tx_lut_10": {
            /* TX gain table, index 10 */
            "pa_gain": 2,
            "mix_gain": 11,
            "rf_power": 16,
            "dig_gain": 0
        "tx_lut_11": {
            /* TX gain table, index 11 */
            "pa_gain": 3,
            "mix_gain": 9,
            "rf_power": 20,
            "dig_gain": 0
	"tx_lut_12": {
		"desc": "TX gain table, index 12",
		"pa_gain": 3,
		"mix_gain": 10,
		"rf_power": 23,
		"dig_gain": 0
	"tx_lut_13": {
		"desc": "TX gain table, index 13",
		"pa_gain": 3,
		"mix_gain": 11,
		"rf_power": 25,
		"dig_gain": 0
	"tx_lut_14": {
		"desc": "TX gain table, index 14",
		"pa_gain": 3,
		"mix_gain": 12,
		"rf_power": 26,
		"dig_gain": 0
	"tx_lut_15": {
		"desc": "TX gain table, index 15",
		"pa_gain": 3,
		"mix_gain": 14,
		"rf_power": 27,
		"dig_gain": 0
    "gateway_conf": {
        "gateway_ID": "0000000000000000",
        /* change with default server address/ports, or overwrite in local_conf.json */
        "server_address": "router.eu.thethings.network",
        "serv_port_up": 1700,
        "serv_port_down": 1700,
        /* adjust the following parameters for your network */
        "keepalive_interval": 10,
        "stat_interval": 30,
        "push_timeout_ms": 100,
        /* forward only valid packets */
        "forward_crc_valid": true,
        "forward_crc_error": false,
        "forward_crc_disabled": false
433 MHz band support and alternatives
EU433 Proposal
(Arjan) #2
What are the values based on? Just a list you got from RAK support? Why these frequencies?
(I’m quite sure TTN could have easily created a “random” list of values within the frequency range themselves as well, so I’m quite sure TTN needs the reasoning to elect these frequencies? And given the formatting of the JSON, especially the sudden different approach between everything up to "tx_lut_11" and as of "tx_lut_12", this just feels like a quick Saturday morning list to me. But I’m no expert at all.)
(LoRaTracker) #3
According to IRE2030, which lists the available frequencies in the UK the range is 433.05Mhz to 434.79Mhz, so taking bandwidth into account, the min and max frequencies are outside of whats allowed in the UK.
Is not the rest of Europe the same ?
#4
(Jose Marcelino) #5
The first three frequencies 433.175, 433.375 and 433.575 are the three mandatory channels in the EU433 plan according to the LoRa Alliance (LoRaWAN Regional Specifications) so that seems OK.
(Arjan) #6
For those, Hylke wrote in September 2017:
I wonder if that includes support for downlink.
(Arjan) #7
For future reference, as written on GitHub:
@johan
We’re not planning to support EU433 officially. With V3, this will be much easier to do for private networks. In EU, on the public network, we stick to 863-870 MHz.
Maybe the above only applies to usage in Europe itself; some other countries might want to use EU443 as well, like Israel:
Country name Band / channels Channel Plan
Israel 433.05 - 434.79 MHz EU433
915 - 917 MHz Other
(Ufg Ky19aprs) #8
Hi Sowislo,
regarding the following channel,
as mentioned by others, this will lead to illegal out of band transmissions. Please see my post here:
EU433 Proposal
(Julianfer5) #10
Hey all, would it be possible to set up a couple of uplink / downlink channels on the EU433 band in such a way they don’t exit the limited frequency range. Do I just simply fork the repository and submit a band proposal? I’m looking at setting up some 433 gateways.
#11
important to know if your thinking of using TTN.
TTN Gateway blocked
(LoRaTracker) #12
With 868Mhz well established in Europe, why use 433Mhz ?
(Julianfer5) #13
I live in Spain and Spanish legislation allows higher power on 433 and higher duty cycle, there also seems to be quite a lot of 433 hardware on the market and I am certain that some users like myself also have access to them. I am not suggesting a major network change but simply having the option of running 433.
Cheers,
Julian
(Ariedel) #14
434 Mhz & LoRa is used by this project https://fossa.systems/home/fossasat/
“Set to launch in Q3 of 2019, FossaSat-1 will be Spain’s first pico satellite.”
(Arjan) #15
To me, what you’re asking would be a major change. I’d fear things like Can Australian users agree on using a single frequency plan? for Europe, and would rather not support EU433 in Europe.
